Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
After a heavy rain storm pilot went out. When tyring to light pilot it goes on but won't stay on.
    President:
  • Teledyne Laars Master
  • 1,378 Answers
Can you get a millivolt reading on the generator leads that come up to the gas valve? If so, are they climbing about 350mV? If not, replace the pilot generator.
If the reading is that high or higher (it should get into 500mV or more on a good generator) and it still will not keep the pilot lit, the gas valve is failing.
Posted on Jun 18, 2009
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
Propane wall heater
Clean pilot , Then check thermocouple if it is not staying alight .
May 03, 2017 | Heating & Cooling
My wife and I were headed on vacation and got caught in a rain storm for a good part of the day. The next day was better, but we got caught in rain again. We thought luck was on our side when we finally...
Hi, Paul some bikes can handle moisture better than others depending on age and 99% of the ones that don't start after getting wet just need a little time to dry out then they are good to go. WD40 works wonders when sprayed in critical electronic areas, ie. coils, spark plugs, safety switches etc.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won start after transporting in rain GL1500 Information Questions...
Bike won start after the rain ninjette org
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VF750C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 22, 2017 | 1995 Honda VF 750 C Magna
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Furnace Pilot Light Won't Stay Lit
Here is something similar that happened to me. I went through the same steps you went through and upon closer inspection, I found a spider had made a web inside the supply line only letting a small trickle of gas through. Have you verified there is nothing blocking the line?
Oct 02, 2012 | Heating & Cooling
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gas is on pilot won t light
Hello there: The problem you mention is not that clear. The pilot won't light or the pilot lighted but won't stay on is two different problems. If the pilot won't even light or no gas coming out off the pilot when you push down the pilot button it means the pilot orfice is blocked and what it need is cleaning the pilot orfice. If the pilot light is on but goes off when you release the button then the thermopile need to be changed. Hope this can help.
Sep 23, 2010 | Frymaster Dean Kitchen Appliances - Others
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
258 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
