Question about Zanussi zwh6160p
Zwh6160p Cannot select super quick wash?
My zanussi zwh 6160p lets the water into wash but the drum won't move, I've checked the belt, motor and all seems ok, what could it be
if its around six years old it could be worn motor brushes not too expensive to buy or replace depending on yours skill levels.
Oct 02, 2016 | Zanussi ZWH6160P White 60 cm Washer Front...
Super general washing machine (SGW 5800) front loader wont stop
Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
Apr 29, 2014 | Washing Machines
My washing machine sometimes fills with water in between washes so I have to drain it before putting a load on why is this
is it clean water or dirty water
if it is clean water you need to change the water valve
if it is dirty water then you need to lift the drain hose higher if it drains below the sink ( to stop the back fill from the sink)
Jan 29, 2014 | Zanussi zwh6160p
Zwh6160p set programme,start/pause light flashes, when pressed machine doesn't start, door does not lock either
Is the door shutting at all or is it just not clicking shut , there is a pressure switch / electronic switch on the door catch mounted on the machine main body which prevents machine running if the door is not shut correctly.
Nov 28, 2013 | Zanussi zwh6160p
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
The picture is not full screen it has a gray bar on each side of the screen
go to quick menu select the picture size you will a selection native,wide,4:3,super live,cinema. try to choose it might help thanks need feed back
Oct 15, 2010 | Televison & Video
Hi i waqnt to know that in quick washing select...
The most likely reason is the amount of time needed to fill with water.. Low water pressure in your pipes can make a difference to time needed to fill..Multiply this extra time by the number of fills.. Also a blocked or faulty inlet valve can affect fill time..I hope this helps....Good luck....Nomess
May 16, 2010 | Washing Machines
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
Can you please tell me how to do a quick wash on the beko wm5120w washing machine,.
The only washing machine they have a manual listed for on their site is the WM5140.
CLICK HERE
Should be similar to yours.
You can only select QUICK WASH in 6 programs - listed on page 18 of the manual.
Simply select the program desired, and click the Quick Wash Button.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2009 | Washing Machines
Zanussi zwh6160p Logo
21 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
