Question about Jura Capresso 560 Electric Burr Grinder
Disassembling capresso 560 - Jura Capresso 560 Electric Burr Grinder
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
How do I remove the outer casing of the grinder?
I have a Bodum grinder and the screw was under one of the rubber feet. Not sure if your brand does too.
Feb 15, 2015 | Jura Capresso 560 Electric Burr Grinder
Electrical motor will not work
(Probably too late to be useful, but seeing as I just had the same issue myself...)
There aren't any screws holding the housing on. There are a few indentations around the base where you can insert something to pry. Just work your way around gently, and the housing should come off.
Apr 15, 2014 | Jura Capresso 560 Electric Burr Grinder
Wont vary grind
take it apart see if vents are clogged
or a part broken
Mar 09, 2014 | Jura Capresso 560 Electric Burr Grinder
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I accidentally placed the upper burr in upside down. Now it is wedged in and I can't get it out. Any suggestions?
I've posted this in a few other places on this site (there are many ways to ask the same question), but try putting the clear bean container back on and untwisting as if to unlock it -- the problem isn't just that we put the upper burr in upside down, but then we locked it into place with the bean container. More info at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down or try Capresso at 800.220.5701.
Blade installed upside down
I did this, too. Tell your M-i-L not to feel bad--it's an easy mistake. A Torx T20 driver will remove the center screw. However, when you remove the rotating blade, 3 springs and 3 bearings will come flying out. I'm not sure what order they go in when you reassemble the grinder. I reassembled the unit, and ever since it has not been able to grind the coffee quite as fine as I would like. Have not been able to find any info, such as an exploded parts diagram, to tell me the proper assembly.
Jan 14, 2009 | Jura Capresso 560 Electric Burr Grinder
Jura Capresso 560 Electric Burr Grinder Logo
237 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
