Question about Gateway Computers & Internet
My computer is hooked up to RCA 2870 it keeps losing connection
It works just seems to when it wants which does not help me if I need to do things for work like listen to classes, can you help
    Problem Solver:
  • 14 Answers
How are you connecting the PC to the receiver? Audio patch cable? HDMI?
Posted on Apr 16, 2014
Tip
How To Connect Flat Panel TV to Computer
Hello <br /> First identify your TV's input connections. Most TVs these days have three basic types of inputs. You have your coaxial cable input, the same as your cable box or satellite, an RCA composite input (the yellow, red and white inputs) and an S-video connector. Newer televisions might have Component Video, DVI, VGA or HDMI inputs but the ones listed above are more common. <br /> Identify your computer's outputs. These days computer manufacturers are adding TV compatible outputs on their products so it's easy to have a pc to tv connection when you hook it up. The S-video in particular seems to be popping up on more and more computers, so a PC to TV S video connector might be what you need. You can shop for S-video cables all over the place online. Mostly you will find the usual VGA output that the regular monitor hooks up to (see more later on VGA cables). The newer multimedia computers will probably have all high definition outputs that connect directly to your HDTV, but for now we will deal with what most people have for both computers and televisions. <br /> Find the appropriate adapter for your connections. You may need to get a computer to TV cable so you can hook up your computer to the TV. If you have an HDTV, you may need a VGA to component cable. This VGA to component cable connects your computer to a HDTV and acts as a converter. (And that computer could be either a Mac or a PC.) <br /> A PC to tv connector has a VGA adapter on one end and (usually) a selection of connectors on the other (S-video, RCA composite and Component). The good thing about these is that you can take it from TV to TV and you'll be able to hook up computer to TV for all of them. I highly recommend a wireless adapter. It costs a bit more but wireless is worth not having a big cable mess and not keeping your computer near your TV. <br /> or you can get help from this video <br /><br /><img src="utube.png" /><b><i> You-Tube video "ZCN-nN1orYE" placeholder (do not delete) </i></b><img src="utube.png" /><br /><br />Hope this helps, if so do rate the Tip.<br />
on Jan 25, 2011 | Televison & Video
I'm trying to hook up an Altec Lansing computer speaker system. I can't get the speakers to work. I'm use to speakers having a plug that fits the little green speaker outlet, this seems to...
You need to get one of these or something like it :
http://www.google.com/products/catalog?hl=en&biw=1024&bih=649&q=rca+to+mini+adapter&um=1&ie=UTF-8&tbm=shop&cid=15600543032554495997&sa=X&ei=2v89Tr_lCqjYiAL69aXDBg&ved=0CD4Q8wIwAw
it is a called a Mini/Rca Adaptor
Please Rate my Advise if it is helpful.
Aug 07, 2011 | Altec Lansing Multimedia Computer Speakers
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
Jan 25, 2011 | LG 32LG30 32 in. LCD HDTV
I have a rca dcm315 cable modem a I can connect to the internet through a usb cable but not a ethernet cable. All I'm tring to do is hook up 2 computers to the internet and I just can't seem to get the...
When switching from USB to Ethernet (Or opposite) you have to unplug it, then hook up the Ethernet cable and plug it back in.
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Apr 01, 2010 | RCA Cable Modem DCM315R (11603540)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How to hook the thing up and can it be hooked to a home computer
You can download the manual from Pioneer at this page. Just click the "owner's manual" link. There are diagrams and hookup information in the manual.
It is possible to connect your computer. You can run an audio cable from the line out jack (the one that would normally connect to a set of computer speakers) and connect it to an available input on the receiver (such as the auxiliary or CD inputs). You would need to pick up an adapter or cable to provide the right connections at both ends. The computer will normally need a stereo mini-phone plug, and the input at the receiver is RCA plugs.
May 27, 2009 | Pioneer VSX-D810S Receiver
Connecting
i have the same problem i moved and hooked everything up and now i cant get my router up and running or at least not with the internet. when it plug straight up to the cable modem i get the internet but when i hook it up to the network it has limited or no connection and i have been working on this thing for about a week. i think it is something small that i am over looking or something. i have it from the wall to the cable modem,from the cable modem to the router and then from the router to the computer. the cables i am using all work because i tested them straight from the computer to the cable modem and they worked
if you could help i would be greatfull and if need more info just tell me and i will do my best
Jul 04, 2008 | NetGear WGR614 Wireless Router
Flash errror
I was having the same problem as the rest after hooking my RCA S2001 MP3 player up to my new computer that is running Windows Vista Home. I did the following to fix my MP3 player on my old computer which is XP Home.
I fixed my player by loading the latest firmware version (1.5 at this time and can be found at http://www.rcaaudiovideo.com/product.aspx?product=124&post=6 ). After you load this application to your computer you access the update device application from the start menu/programs/RCA digital Audio Player/Jet/Update device. One thing that I had to do that had not been mentioned yet in this forum was selecting "Format data area"
Doing this wipes your device completely clean but it allows for you to keep using the device. The update device program will give you additional information after the update and format.
This should fix your device if not contact RCA through the same website above to ask additional questions.
Jan 06, 2008 | RCA JET S2002 MP3 Player
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Computers & Internet Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
