Question about Indesit IWSC 61251 ECO White 595 mm Washer Front Loading, 6kg, A Energy Rating
Smoke coming from the drum
We did a wash and smoke started comingfrom the drum. the clothes smell of smoke. i took off the back panel and there is ssot on the panel.
2014 Altima -I got an oil change at Midas (worst mistake ) about two months ago. Apparently the guy half assed it and my car started smoking under the hood after I drove off. Brought it back left again and...
Their must be some oil stored somewhere and it is dripping on your exhaust manifold,but never pressure wash your engine, could cause worse problems,in time the smell will go away,just be patient.It will burn off in time.
Mar 06, 2017 | 2014 Nissan Altima
Smoke coming from inside drum after spin cycle
The noise would possibly indicate that your drum bearings are on their way out, this would more than likely mean a new spider assembly, tripod in shape and houses the bearings through the drum, as well. They come in kits or bearing assembly alone for various prices, usually around 40 pounds for the kit but it would be a very difficult job if you are not familiar with this type of work, bearing extractor kits are best used but more cost, drum seals may also be needed.
Jan 23, 2014 | Hotpoint WMA35 Front Load Washer
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Smoke coming from vents smells like antifreeze
Your heater core under the dash usually on the right side is leaking,unless your a mechanic? Take it to one.
Oct 17, 2008 | 1991 Ford Taurus
Um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Jun 20, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Oct 28, 2006 | Hotpoint WMA35 Front Load Washer
Indesit IWSC 61251 ECO White 595 mm Washer Front Loading, 6kg, A Energy Rating Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
