Question about Health & Beauty
How do I change silvercrest scales to read st/ lbs from kg.
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
skaterkid307
  • 86 Answers
SOURCE: my scale reads 0.0.0 st-lb how do i put it back
press buttons on it or get new instructions
Posted on Feb 20, 2010
SOURCE: need to reset
just keep pressing the cancel button for 10 seconds,,, it will start blinking,, then reset it to your desired point
Posted on May 15, 2010
joeguest2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
SOURCE: change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Posted on Jun 03, 2011
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
Cannot configure camry ef522bw scale back to lbs
Check the bottom side of your scale. Mine has a switch to go from lbs to kg and st???. Anyway, check on the bottom ;)
Apr 16, 2013 | Health & Beauty
My homedics mibody body manager scale will not change between lbs, stone and kg. I have tried pressing the button on the bottom of the scale however this does not work.
Probably too late, but I've just had the same problem and if you push the foot of the scale in for a couple of seconds the 'kg' display starts to flash and then you can use the button on the bottom to change to lbs.
Sep 12, 2011 | Kitchen Appliances - Others
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Change scale from kg to lbs
Apr 23, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Health & Beauty Logo
206 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
