Question about Dishwashers
I have a Fisher and Paykel dw60cew1 dishwasher that has come up with error code E4 which is saying blocked drain bent drain hose, I have checked and cleaned everything including the filter but gets 20mins into cycle and comes up with the error again.Any help?
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
SOURCE: Fisher & Paykel drawer dishwasher will not drain properly
We had this problem. wqe had a small bone blocking off the drain tube a bit. Take all the parts on the inside of the draw out ie mesh rack, remove the strainer, steel plate and remove the spinner. Now get a small pipecleaner or brush and poke it up where the strainer inlet is. You will probably see it pock through the centre where the spinner is. Give it a go.
Posted on Sep 25, 2008
  • 171 Answers
SOURCE: Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
RescueTech
  • 145 Answers
SOURCE: blocked drainage hose in Fisher and Paykel top dishdrawer DD603
Hello there..
How do you know the hose is blocked at all? It's rare for that to happen, I work on these machines daily as I am a Factory Authorized tech. You need to be careful in your approach to this, that is an expensive machine and it can be damaged by improper service procedures.
For starters, there is a flap valve on the end of the drain hose that would prevent you from introducing any sort of pressure backwards into the machine via the drain hose. For example, if you took and tried to blow air thru the drain hose outlet end, you would force that flap closed and create pressure in the hose. Also putting caustic drain cleaning substances is very, very bad for your machine and can cause some serious damage.
I will be happy to try to assist you, but let's start at the begining, shall we? What prompted you to conclude that the drain hose is 90% blocked? The first thing you should do is take out the rack, wash arm and tha large stainless steel filter plate. Next, pull the rotor up and out of the pump base (none of these procedures require tools) and make sure the grey impeller is not "freewheeling" or has become detached from the rotor shaft. The blue wash impeller on the top and the grey drain impeller on the bottom must be "one to one" meaning they are firmly connected to the shaft of the motor and turn together.
Next, check the tube or passageway in the drawer between the sump (where that small removeable filter screen is) and the pump's sump area (where you pulled up the rotor)
If you have any blockage, it will be in that tube.
There is some glitch here where I do not get notified of response to questions, so I will check back to this post.
Posted on Dec 14, 2008
  • 3247 Answers
SOURCE: my fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Posted on Nov 10, 2009
My fisher paykel dishwasher will not drain water it washes a while and when spray water it stops and e5 comes on screen leaving water in machine
See if the water hose to the unit is kinked or otherwise restricted. If the water hose seem ok them you might have a defective water inlet electro valve. The video may help, be patient e5 is explained Fisher and Paykel Dishwasher Error Codes
Dec 14, 2016 | Fisher Washing Machines
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
My Fisher & Paykel double dishwasher won't drain completely
It may be a blocked hose. First point to check is under the sink where the thin corrugated drain hose joins the sink drain. If it is a double dish drawer there will be two hoses, one black and one white. The black hose is usually from the top drawer. They are held on by spring clamps.
If this is not the problem, post again.
Feb 07, 2014 | Fisher and Paykel Dishwashers
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
Ensure the water is connected
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
Dishwasher tablet not dissolving during wash cycle
I am not sure if you can use dishwashing tablets with this model of dishwasher. These are designed mainly for powder only - you should be able to shut the detergent compartment door before starting the dishwasher.
Make sure the compartment is not blocked preventing inlet water from circulating through.
Dec 30, 2012 | Fisher and Paykel Dishwashers
E4 error fisher and paykel dishwasher
There is a Y shape pipe under the sink's piping & it was blocked so I drilled & open a hole then the machine could has drained & worked.
Nov 08, 2012 | Fisher and Paykel Dishwashers
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
particles..
Feb 19, 2011 | Fisher and Paykel Dishwashers
Fisher Paykel Dishwasher drawer not draining water.... F1 error... Drawer is holding water......possible hard water build-up...
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
May 05, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher&Paykel DW60 drain pump is blocked.
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
