Question about Ovens
Flue for a shacklock chip heater
We have an old shacklock chip heater/wet back in our home without a flue. Can I still get them?
Shacklock chef manual
Usually (with oven unplugged) the burner will tilt up and is held in by a screw or 2 and has 2 wires attached (normally push on terminals). Have you read these with an ohmmeter to see if they are bad? The oven elements need the back cover removed and you will see the element connection and maybe a screw (if the screw isn't on the inside). It too should be checked for continuity before buying new ones.
Dec 06, 2013 | Ovens
SHACKLOCK TM620D double oven - hinge spring broken. Where can I find a replacement in NZ, preerably Wellington?
Try these: http://www.egleys.co.nz/index.asp?pageID=2145828187 http://www.dougsmithspares.com.au/Appliance%20parts%20New%20Zealand%20NZ%20delivery.htm
Oct 28, 2013 | Ovens
I'm looking for the service manual for a Rayburn solid fuel cooker
What do you need to know? They are so simple. Clean out space under hot plate now and again to prevent soot build up under the flue outlet space, have chimney swept now and again..(annually depending on use) .look in flap on bottom of flue pipe should tell you if needs sweeping.
Sep 06, 2010 | Ovens
How do I reset the clock on a shacklock multifunction oven? Has 5 buttons, timer, a picture with what looks like steam above a square, auto/man and a knob that can turn either left or right.
press timer (picture with bell) adn cooktime ( picture with what looks like steam above a square) buttons simultaneously while turning adjacent knob clockwise until readout registers current time. Release both buttons and clock is reset.
Oct 09, 2009 | Ovens
How do you replace an oven door lining
no need of spl.tools it can change by openig screws left bottom of the door
Aug 05, 2009 | Fisher Ovens
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
Do we need an exhaust flue for a southbend half size gas oven?
Depending on your local code, you will need an exhaust hood due to the byproducts of the gas burning. Some locals allow for electric ovens to go without hood. Gas units generally require a hood system with proper fire suppression equipment. You may want to check with your local fire and building inspectors.
Mar 22, 2009 | Southbend S560DD (Gas) Oven
Electric oven
was there a lightening storm (that may have zapped the micro-controller chip) prior to the problem?
May 06, 2007 | Maytag MEW5530D Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
