Question about Nikon COOLPIX L3 Digital Camera
The lens is struck and it is also tilted - Nikon COOLPIX L3 Digital Camera
WHEN SWITCHING ON THE LENS COMES OUT HALF WAY THEN GOES BACK IN. DISPLAYS ERROR MESSAGE "LENS PROTECTION".
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jun 21, 2011 | Cameras
My camera powershot A560 .... lens error !!
get estimate before you decide. It will be good to have it checked at the Canon service as you do not have to run around for spares.
May 28, 2011 | Canon PowerShot A560 Digital Camera
Lens error
May 09, 2011 | Cameras
Camera shows lens error....will not open or close
get estimate before you decide. It will be good to have it checked at the service as you do not have to run around for spares.
Apr 06, 2011 | Cameras
Lens will not close...camera will not turn on/or off....screen shows lens error
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for spares.
Apr 06, 2011 | Nikon Cameras
The lens extends and retracts constantly after turning it on. Battery has a good charge.
It is also possible that the mechansim is struck .Use some high pressure jet air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at any camera/Kodak service as you do not have to run around for spares.
Mar 13, 2011 | Kodak EasyShare P850 Digital Camera
Lens error 41. What i must to do?
Feb 18, 2011 | Praktica Luxmedia 7103 Digital Camera
Battery went dead when using and lens is stuck open - although now fully charged lens wont return
Feb 18, 2011 | Cameras
Cybershot W210-My Camera lens got stuck and neither the camera is getting on nor the lens is getting closed
get estimate before you decide. It will be good to have it checked at the authoirized service as you do not have to run around for spares.
Feb 07, 2011 | Cameras
Lens error
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for the damaged spares.
Jan 06, 2011 | Nikon COOLPIX S610 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
20 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
