How to wire a fb4 footswitch for line6 amp - Computers & Internet
  • 35 Answers
The Line 6 controllers use a standard CAT-5/6 cable with standard RJ-45 ends.
Posted on May 05, 2014
Foot switch appears to be wired backwards. The Shape pedal turns on the UtraBass and the UltraBass pedal turns on the Shape (Channel 2).
Foot pedals are usually NOT interchangeable... The correct footswitch would come with the amp so be sure it says Behringer on on the footswitch. Apparently some sellers have foisted off VOX footswitches which may not work with the Berhinger.
Sep 16, 2011 | Behringer Ultrabass BXL3000 Bass Guitar...
Wiring a crate 2 button footswitch to work with the prometheam ibenez bass amp...can it be done?
Mixing brands on footswitches, even within the same brand but different series is NEVER a good idea. While many can be converted by elecvtronics competent techs, the effort is usually not worth it for anything other than the simplest footswitch.
Aug 26, 2011 | Ibanez P500H Promethean Bass Amplifier...
When I plug my P803 2 Way footswitch into my Haze40 amp the effects light flashes and the footswitch will not change channels or effects.
The P803 is designed to work with the "Valvestate" and Tube amps. I don't think it is compatible with the Haze40 since they have an optional 4 button footswitch so the optional one would necessitate different interface than the P803.
Jun 02, 2011 | Marshall Amplification Marshall P803 2-Way...
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I have the fender accessories footswitch and the cyber twin. The pedal has stopped working and I have replaced the cable but still does not work. Is it the pedal or the amp? The amp buttons still work...
Verify the footswitch with an ohmmeter. You should find that each of four pins should have continuity to pin 2 of the connector when the switch associated with the pin is pressed.
Note the pin numbers on the connector seem to have a weird layout. Here is a link to your amp schematic. The Footswitch interface is shown on page 3 of 12.
http://elektrotanya.com/fender_cyber-twin_sch.pdf/download.html
Use the ohmmeter to check each wire in the cable is good. SOme cables, unless the official one for the unit, may lack some wires.
The amp "reads" the footswitch state into a register which is then read serially. The inouts are pretty well protected from user mistakes. With the schematic you should be able to analyze the failure.
Feb 27, 2011 | Fender Accessories Footswitch for Cyber...
I seem to have the wrong cord on my footswitch as the female end on my amp is one of those computer types, How can i get around this?
The footswitch should be a 1/4 inch stereo type (TRS) plug to fit the footswitch jack of the MG250FX. It is a three wire connection.
Jan 06, 2011 | Marshall Amplification Marshall MG250DFX...
Fender Hot Rod Deluxe Footswitch
Main thing to verify is that the particular footswitch and cable you have is specifically for that amp. If it is not the right one, that is your problem as there is very little compatibility among footswitches.
Looking at the schematic, plugging in JUST the cable shifts operation as you observed. This uses a crazy circuit in which AC is applied on the cable and the footswitch has a diode each direction that causes the amp to shift between the states. when you plug a bare cable in, it disconnects the internal diodes and switches for control at the amp, hence the signals float.
You should investigate the footswitch to make sure it is the right type with the diodes resistors and caps that is for the Fender Deluxe.
You can find the schematic for the amp here:
http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_Deluxe_Schematic.pdf
Look at the circuitry of the switches on the schematic at C8. Your pedal should have similar circuitry. Assuming your cable is good, the problem would be in the pedal itself.
Jan 01, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have peavey 212 heritage guitar amp footswitch plug broke. I have new one but i need wire diagram please include colors and speaker conection.Thank U very much
Call the Peavey Customer Service line (number available @ the Peavey site) and get the parts department to email you a schematics on the amp... it has the footswitch wiring on it. And it's free to do this.
Apr 27, 2008 | Audio Players & Recorders
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
