Question about Samsung Galaxy S Duos S7562 White Dual SIM Unlocked
Charging not charging charging connector is ok
    Problem Solver:
  • 17 Answers
May be the wall charger unit, or the phones internal connector is damaged
Posted on Apr 15, 2014
Usb 2.0 charging port doesnt work
The power connectors that are feeding the USB from the inside seem to be ok. The data connections of the USB are bad. Maybe with some very careful professional soldering of the data connectors on the inside of the USB, your problem would be resolved.
Jan 16, 2014 | HP Spectre XT Pro B8U92UT Notebook PC -...
1985 Gl1200 LE Stator wires melted at the plug in
The yellow wires can go in any order (its does not matter as long as the wires are one yellow wire to one yellow wire. They melted most likely because the connector was corroded (had a bad connection) or the charging system has an issue. Put a new connector on it. Run the engine @ about 2500rpm for about 5 minutes, then grab the connector with your hand to see if it is hot to your touch. If the connector is not hot then most likely the charging system is ok and if the connector is hot, then the charging system has something else wrong in it.
Jun 10, 2012 | Honda GL 1200 Ltd. Ed. - SE-i Gold Wing...
Acer Aspire One won't turn on or charge, totally dead. DC power pack tested ok.
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
May 14, 2011 | Acer Computers & Internet
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
Nokia 7610 charging
First insure that is your charger ok? you can try it by using other charger. if your charger is ok then check your charging connector.but if the section is ok in your mobile charger section which name "k" is bad. then you need to change that. thanks
Feb 25, 2010 | Nokia 7610
Battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
May 21, 2009 | Dell Vostro 1500 Notebook
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Retracted USB charging connection
Mine which charges OK also has a slightly recessed connector
Nov 03, 2007 | Konica Minolta DiMAGE X1 Digital Camera
Nokia 6230i
First of all check the charging connector if ok then check the connection to f100(charging fuse 0 ohams) if ok then check the fuse if ok then ckeck the charging diode if also ok then its problum from the UEM change this.
Feb 01, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Samsung Galaxy S Duos S7562 White Dual SIM Unlocked Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
