Question about Konica Minolta Office Equipment & Supplies
Laser polygon motor failure - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,674 Answers
Replace the printhead since you get a polygon motor
Posted on Mar 12, 2017
3 Suggested Answers
  • 110 Answers
SOURCE: laser unit polygon motor failure
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Posted on Oct 22, 2009
  • 123 Answers
SOURCE: unit 11 laser polygon motor failure
Most likely, all the problems you are experiencing are being caused by a bad laser motor assembly. We can send you a motor assembly for the laser unit and you can change it out yourself, however, we will have to charge for the entire unit since it makes one laser unit worthless. You would save on shipping that way. Aligning the lasers is a little tricky, but doable. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Posted on Apr 26, 2010
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
What does L 6 mean?
L6 indicates a laser failure. Most likely the laser assembly polygon motor has failed, 062N00173 is the part number for the laser assembly.
Jan 19, 2013 | Xerox WorkCentre PRO-215 All-In-One Laser...
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
It displays l6
L6 = Polygon Motor Lock Detection
The Polygon Motor spins the mirror which writes the laser signal to the drum.
If switching the machine off/on doesn't cure the error code the only other thing you can do iw just check that all the connectors are plugged in correctly. Polygon Motors do fail and when they do all you can do is replace them. Quite often they will screech or rattle in the run up to failure.
Hope this helps.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Polygon moter failer ?
The polygon motor failure is referring to the Laser Unit (part# - 116-1110-00). This issue somewhat common on the Xerox 7700. Unfortunately the laser unit must be replaced and is pretty expensive (around $1000) Replacing it isn't too hard though, just remove the right side cover and unscrew the two screws on the laser unit and unplug the two cables from the laser to the engine control board. If you do decide to repair the machine iteminc.com has the part online.
Jul 02, 2010 | Xerox Phaser 7700DN Laser Printer
Sharp ar-m208 message
Polygon mirror motor not up to speed. Check the motor, you power supply, and the board the motor it connected to.
Sep 23, 2008 | Sharp AR-M208 All-In-One Laser Printer
Unit 11 laser polygon motor failure
Aug 12, 2008 | Xerox Phaser 7700 Laser Printer
Error code 11 phaser 7700 polygon motor failure
The polygon motor is part of the laser assembly, other wise know as the ROS, Raster Output Scanner.
It normally is not as simple as replacing the ros and moving on.
There are color registration adjustments to be done once the ROS is replaced. You can try contacting
https://www.partsdrop.com/store/
and seeing if they have one. That motor has the mirrors on it that rotate to focus the laser to the belt assembly.
Apr 24, 2008 | Office Equipment & Supplies
44 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
