Question about HP Designjet 110plus nr InkJet Printer
No power My HP Designjet 110plus nr won't power up. I checked the outlet and computer and everything is showing it should come on when power button is pressed.impglass@bellsouth.net
  • 23 Answers
From behind the unit, unplug the power adapter. Now this may sound strange, but it may work as it has in the past.
Hold down the power button on the printer - yes the power adapter is still unplugged. Now plug in the power adapter and wait 8-10 seconds then release the power button. Now power up.
This is a Tech Trick I was fortunante to learn from HP & Canon years back.
Okay if you have no lights and the printer does not power up, check the power adapter to see if it is cold or hot. If it is hot or cold, I would say that the power adapter may need to be replaced.
But your printer may still be under warranty: Go online to www.hp.com and check the warranty status of your printer. You will need the Model Number, Serial Number, and purchase information.
Hope this helps..
God Bless.......
Posted on Jun 18, 2009
What is the cold reset for 110plus
To set to factory defaults, Hold power button down and press the cancel button 3x and the resume button 2x.
Oct 13, 2010 | HP Designjet 110plus nr InkJet Printer
What can be the problem when hp designjet 110plus printer give only color but not black
Either something on the black side is clogged, dried out, or obstructed, or go to HP for a driver update.
Aug 18, 2010 | HP Designjet 110plus nr InkJet Printer
We have HP Designjet 110plus. Our magenta is flashing saying that it is out of ink, however it wasn't. We replaced it with a new cartridge, and it still reads empty. Please help!
Turn off the printer, disconnect and remove everything like power cable, usb cable, cartridges etc.. Connect your power chord and power on, leave it for few minutes (clean the cartridge interfaces not the head, and the corresponding interfaces on the printer). Again shut down the printer using the power button. Reconnect/reinsert everything, and again power on the printer before you connect the Usb to the computer. Now check if it helps or not. This will clear any static memory/voltage. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP Designjet 110plus nr InkJet Printer
NI have a HP Design Jet 110plus nr after put the roll hi start to take the paper roll and take out the all roll witout control. Im chaged the OOPS sensor but is same problem can you help me to solve this...
Im chaged the OOPS sensor but is same problem can you help me to solve this problem
Oct 05, 2009 | HP Designjet 110plus nr InkJet Printer
Clunking noise at power up
Well then it has something to do with that printhead that you just installed yes? Is it in correctly? just stating the obvious.
Jul 14, 2009 | HP Designjet 110plus nr InkJet Printer
Our hp designjet 110plus is not printing black though the indicator shows we have black ink, what seems to be the problem? -Leh
Check whether the black cartridge is dry and whether it is releasing the ink properly.  This you can check by rubbing the paper on the place where the flows.
Else check with a new cartridge.  Even if the problem continues in the printer preferrence you have an option of service.  click on it and the problem will be fixed......!
Mar 13, 2009 | HP Designjet 110plus nr InkJet Printer
How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Mar 06, 2009 | HP Designjet 110plus nr InkJet Printer
the power supply needs to be replaced.
Sep 19, 2008 | HP Designjet 110plus nr InkJet Printer
Print orientation
somewhere i believe you have auto rotate enabled in the driver, and it is cancelling your application's landscape setting. Good Luck!
Jul 15, 2008 | HP Designjet 110plus nr InkJet Printer
HP Designjet 110plus nr InkJet Printer Logo
814 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
