Question about Bosch HBL 5056 Electric Double Oven
I cannot get the cover off the light to replace it
It won't come off no matter how hard we try. Please help!!
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
I am trying to replace the bulb on my Neff B1422NOGB oven. The instructions say to unscrew the glass cover anticlockwise. However, the cover only turns by a small amount (maybe just 5 degrees) and...
A common problem with this manufacturer I'm afraid. The screw thread of the glass almost welds itself to the metal casing it screws into.
It will turn and you can remove it however, the easiest way is to get leverage on the glass. This is best done by using a Baby Boa Strap Wrench, which you can pick up for a few pounds in a DIY store. I have removed many apparantly stuck round glass oven lamp covers in this way.
Aug 26, 2011 | Neff B1421 Electric Single Oven
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
Hi
Daniel
Aug 07, 2011 | Maytag Ovens
OVEN WILL NOT COME ON AND IT DISPLAYS F9. WHAT DO YOU DO?
Hi
Daniel
Aug 02, 2011 | Amana AOCS3040SS Electric Single Oven
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
How do I remove the glass cover to replace the light bulb
Hello, Thank You for using FixYa. I will be helping you today.If its stuck spray some pam around the base of the glass wipe up any over spray and turn the oven on 200 degrees for about 20min. let it cool and try to turn the glass cover.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
Unable to take out light bulb
I can tell you it screws out . i had to break mine to get it out ( the bulb cover that is) Still had some thread left to wind back up.
Dec 22, 2008 | Ovens
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 | Ovens
Bosch HBL 5056 Electric Double Oven Logo
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
