Question about Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display
1.05c parrot how to clear memory - Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display
Memory full on parrot V5.11C how to clear
Please follow the below procedude
Hold the answer and hangup buttons down for 5 seconds {press red and green and hold} the parrot kit will then tell you it is erasing memory then it will say ready for pairing,
Turn on your bluetooth on your phone do a search find and select parrot.Enter default code 1234 when prompted as a pin.
Thank You
Nov 28, 2012 | Parrot SA Parrot Ck3100 Lcd Handsfree...
It keep cumming up with memorry full how do i clear it
Hi, I hope this helps you.
Erasing the memory Click «Yes», and «Clear memory?» is displayed. Confirm by pressing «Yes» and «Memory erasing in progress. Please wait!» - is announced. To cancel, press «No». It is possible to erase the memory and reset the system without using the Parrot menu. To do this, hold the red and the green buttons together.
I have also inserted a link to the manual below. http://www.parrot.com/uk/support/userguides/#CK3000
ALAN
Jun 29, 2011 | Parrot Ck3000 Evolution Universal...
Hi How do I delete the memory on my ck3100? I've gone to settings and then paired devices but it tells me there are no paired devices so how do I delete the memory?
According to this link:
http://forum.parrot.com/english/viewtopic.php?id=6158
You have to update the firmware to clear the memory (although it also implies there is a reset option)
Oct 12, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
The memory is full on my parrot ck3100 and it is preventing me pairing with my nokia 63600 how do i clear the memory
You will need to go to setting / paired devices / select the phones you want to remove / then select delete. Hope this helps.
Aug 20, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Clearing parrot minikit memory
Just press on the green and the red buttons at the same time, you will have erasing memory in progress, please wait. And then please pair device.
Mar 20, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Cannot clear parrot memory
go to settings, paired devices and delete all paired devices, the go to settings pair with phone and start new pairing.
Aug 16, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Nokia 5800 wont connect
Have you used the Parrot with another phone? In which case you need to clear it's memory to put it back into pairing mode.
Hold down green and red together until she tells you memory is cleared, then she prompts you to pair your phone.
Jun 17, 2009 | Parrot Par Ck3000 Evolution Ck3000...
My kit will not allow me to pair a phone, it comes up memory full i have unpaired all phones, how do i clear the memory (Parrot 3100 to Samsung tocco)
Disconnecting your car battery would clear the memory but ideally you need to update the firmware of your car kit through a bluetooth connection, instructions and software to do this can be found at http://www.parrot.com/uk/support/downloads. You need the Parrot software update tool. Instructions to do this are at http://www.parrot.com/uk/support/downloads/texte_fck_2/image/ck3x00_update_procedure__en.pdf for XP or http://www.parrot.com/documents/en/support/parrotck3100-vistaupgradeprocedureeng.pdf for Vista. Hope this helps if you haven't figured this out for yourself already.
Jan 07, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Parrot CK3100 Bluetooth Phone Kit
how do I clear full memory from parrot blue tooth phone system
Jun 20, 2008 | Parrot Hands-Free Car Kit with LCD Display...
Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display Logo
47 people viewed this question
Top Parrot SA Cell Phones Experts
Al
Al
Miroslav Rusev
Miroslav Rusev
repairphone
repairphone
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
