Question about Fisher and Paykel WL26CW2 Top Load Washer
What does it mean error 249 on washing machine fisher paykel
  • Fisher and P... Expert
  • 554 Answers
The pump is blocked or faulty
What does it mean error 249 on washing machine fis - wpgei3kfyonrgaaaabjru5erkjggg==
Posted on Apr 20, 2014
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
  • 28 Answers
SOURCE: Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Posted on Jun 21, 2008
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
  • 713 Answers
SOURCE: Fisher and Paykel GW612 - Lights showing
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
Posted on Jul 17, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
How do you resolve Fisher Paykel fault code 249
From Service Manual for 249 error
249. (11111001) SmartPump Timeout Fault (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for 3 minutes.
This fault will generally be caused by a problem in the pump system, from either a blockage, or restriction in the pump system. This fault will also flag if the machine is 'By-Passing'.
Primary Source: Pump System
Action: 1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose. A 1-meter extension
hose of the same diameter fitted to the existing drain hose is
the maximum allowable length.
3) Check that the machine is not pumping to a head that
exceeds the pumps limits (2.4metres is the maximum head
height).
4) Remove the inner bowl and check that the pump hood hasn't
been fitted around the wrong way.
5) Check for lint streaming from the pump hood that may be
blocking the pump cap inlet.
6) Remove the pump hood and cap, check for lint, grit and
debris.
7) Check for free movement of the impeller and that the impeller
hasn't come off the rotor.
8) Check for free movement of the flapper (replace if broken or
damaged).
9) Check for lint and foreign object in the ports of the pump
housing.
Jun 23, 2015 | Fisher and Paykel Washing Machines
I have a fault code 249 from my Fisher and Paykel 8kg washing machine. What does this mean?
I didn't know the codes went this high! it will be a motor controller fault I would suggest, as all other faults above 140 are motor controller.
Aug 28, 2013 | Fisher and Paykel (IWL12)
Fisher and Paykel Aquasmart
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Action: Follow procedures as for Fault Code 249.
Action: Replace Motor Control Module.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
On a fisher & paykel washing machine what does it means by fault code 12. The washer is approx 8 years old.
Hi just read posting.Error code 12 means FLOOD PROTECTION ERROR.Has you machine overflowed or does not pump the water out quickly?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Sep 03, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
See all Fisher and Paykel WL26CW2 Top Load Washer Questions
Fisher and Paykel WL26CW2 Top Load Washer Logo
76 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
