Question about Honeywell Heating & Cooling
The digital display is not functioning
I have T8000C Honeywell thermastat. The digital display is not displaying. The 3V fuse on HVAC circuitboard was blown and has been replaced. The wiring at the thermastat is reading 24vac across all the wiring options yet thedisplayisnot reading. Is the thermastat shot or is there something else I need to do?
  • 4 Answers
The thermostat could be bad. It may have gone bad on its own or due to a short in the supply wiring. Sometimes mice will chew on the wiring in the wall that leads to the thermostat. But I wouls change the thermostat. They do go bad. Make sure you turn the inside unit off first in case you accidently touch wires together. This will blow the transformer inside the unit if the fuse doesn't blow first. I even scene thermostats with fuses inside. So you may want to take the thermostat apart and check for inside fuse also.
Posted on Jun 18, 2009
I have a HVAC thermostat that had "always-on" backlit display.It still works but the display goes off in a few seconds.How can it be fixed to always stay on?
If the display on your thermostat resembles the illustration, it is an LCD not backlit (as in TV). The reason the display turns off is to prevent premature failure.
Aug 10, 2016 | Honeywell TH5110D1006 Focus PRO 5000...
What do I do My Honeywell thermostat T8411R is not working. Its display is dark
The thermostat wire may have and break and not getting power. Honeywell Customer Assistance at 1-800-468-1502
May 08, 2014 | Heating & Cooling
How to reset Honeywell UDC2500
The procedure to restore the factory configuration on the Honeywell UDC2500 is on page 180 in the PDF manual from Honeywells website.
Steps:
1. Turn off power to the instrument for at least 5 seconds.
2. Turn power back on and simultaneously press the "FUNCTION" and the UP keys. This must be done while "TEST DONE" is being displayed.
3. If step was performed correctly, the instrument will now display "UDC" [Upper line] "UPDATE" [Lower line]
4. Press the "FUNCTION" key. The instrument will now display "DIS" [Upper] "RESTORE" [Lower]
5. Press the up arrow key. The instrument will display "CFG" "RESTORE".
6. Press the "FUNCTION" key. The instrument will display "DOIN" "RESTORE"
After that the instrument will go through a restart.
Hopefully this helps.
Mar 04, 2013 | Honeywell Udc2500 2 Output Relay Tc Input
Honeywell t8000c display is blank, unit doesnt run
I would say that you have one of two issues. Either your thermostat is bad or you do not have 24v coming from the heating unit. In this case the problem would be in the low voltage circuit of the heater. At the heater you should have 24v AC when you place an electric meter across the R terminal and the C or W terminal. If you have no vaoltage across the R to either the C or W then you have a bad transformer or a blown fuse in the furnace. If you do have voltage ther and also at the t-stat then the t-stat has gone bad, replace it.
Nov 14, 2009 | Honeywell Electronic Programmable...
T8000c honeywell thermostat is blank
This unit doesn't require a battery. It runs off the 24v from the unit. Check that your transformer is still working. Check the control board for 24v pwr. and main pwr. Check your breaker to the unit. It could be as simple as a bad stat too. You can check by using a jumper wire and jumping across from r term. to y term.
Apr 10, 2009 | LG Art Cool LA121CNP wall/window Air...
T8000C Honeywell - fuses???
So the indoor fan is running and blowing air inside but it is not cold?? Is the outdoor fan running ?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 20, 2017 | Honeywell Electronic Programmable...
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
Apr 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Heating & Cooling Logo
385 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
