Question about Apple eMac Desktop
EMac stuck on loading screen
I had my e-mac networked to my iBook and was transferring music files when all of a sudden everything disappeared except for my desktop background, when I restarted the computer it started up just fine except i could not view any of my desktop folders. When I restarted it a second time it wouldn't get past the very first loading page, and thats what it has done ever since.
  • 21 Answers
Well i don't know of a fix for the issue u have, but i do have a tip and you might be able to fix the issue you have this way as well. But if you plan on transfering files from one mac to another esp. if one is either an older mac or a portable. you would always want to make one or the other a target disk instead of two stand alone mac's.
Why, because your eMac's older and the data transfer might be failing or can't process the data fast enough to get broken down to bits to be put back on the other end thru the cat5 line. But to transfer files of over 1 GB i would recommend you start the iBook in target disk mode. But since your eMac is the one with some issues put the eMac as the target.
To connect two mac using TDM (Target Disk Mode) you will need to get either a 6-pin IEEE to 6-pin IEEE firewire 800 cable, a 6-pin IEEE to 9-pin IEEE firewire 800 cable, or a 9-pin IEEE to 9-pin IEEE (if your eMac has a 9-pin port) firewire 800 cable.
Then you connect the cable to one of the eMac's 6 or 9 pin ports and the other end to one of the iBooks firewire 800 ports. (the iBook has both the 6 pin eMac stuck on loading screen - a48d559.gif and the 9 pin. 24a3000.gif800 ports) To start up as the target disk you press and hold T immediately after pressing the power on button. once you see the firewire symbol bounce around the screen you can let go. Now its like connecting to a external hard drive.
Posted on Jul 07, 2009
  • 1 more comment
  • Luke Kim
    Luke Kim Jul 07, 2009
    Then you connect the cable to one of the eMac's 6 or 9 pin ports and the other end to one of the iBooks firewire 800 ports. (the iBook has both the 6 pin and the 9 pin. 800 ports)
  • Luke Kim
  • Luke Kim
Need to transfer data from old computer to new computer
You have a bad situation. Only a mac repair pro can help you in this case as it's hard to arrange some tools to solve the problem. A pro can gain access to your emac hard drive and free up some space or transfer your data using special tools and knowledge. Thank you and good luck.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Oct 17, 2014 | Apple eMac Desktop
Have apple eMac forgot user password can you help
You need to start up from the system cd for the eMac then use 'Password Utility' to change the password.
Alternatively, if you are transferring the files to another Mac, you can start up the eMac in 'Target Disk' mode by holding down the 'T' key during start-up until a Firewire symbol appears on the screen. The computer can then be connected to another Mac which will see the eMac as an external HD.
Apr 20, 2014 | Apple eMac Desktop
Looking for instructions on how to install blue tooth card into e-mac g4
Here ya go.
should give you what you need
[PDF] iBook G4 (Late 2004) Getting Started (Manual) File Format: PDF/Adobe Acrobat - Quick View
install one, see “Installing an AirPort Extreme Card or Additional Memory” on page 51. ... You can also find information on the Apple Bluetooth ...
manuals.info.apple.com/en/ibookg4gettingstarted.pdf - Similar
Jul 12, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
I can't put music into my sansa clip on my mac ibook wat can i download?
There's a Sandisk Answers support site. Entering mac leads to:
http://kb.sandisk.com/app/answers/list/kw/mac/r_id/101834/search/1
Next link ( 4. ) tells how to use iTunes on a MAC for transferring files to mp3 format:
http://kb.sandisk.com/app/answers/detail/a_id/1141
Download iTunes ( version 9 ):
http://www.apple.com/itunes/download/
Manual for the Sansa Clip ( readable with Adobe Reader ):
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
After transferring music to the supported format,
use the Drag and Drop method as described on page 11 (=page 9) for putting songs in the MUSIC folder.
Look on page 22 (=page 20) for the supported file formats.
When more help is needed, just post a comment.
Nov 21, 2009 | Audio Players & Recorders
I have a G4 ibook. When I try to load Rosetta Stone on computer it acts like it wants to load but then all the sudden it goes to a blank screen. If you can help please do. The software worked the first...
Isolate the problem to make sure its not the optical reader.  Get a music CD and try to see if it will play, then get a DVD out to see if it will play, then get another software disc to see if it will play.  Will all three play fine?  Then your Rosetta disc is fu.k.d up from heavy scratches, smudges, or corrupt manufacturing process. Otherwise, your optical drive needs to be replaced if it has problems playing the other discs.
Nov 11, 2009 | Computers & Internet
After starting my emac a screen comes up asking me to log in above it says darwin/bsd (user-s-emac-2.local) (console)
Sounds like some of your system files may have been corrupted. Restart your computer with you OS disc, and when it launches, go to the top menu and look for "Disk Utilitiy". Launch and see if you can repair the files that way. If not you may have to reinstall the system software. If so, choose the option that won't erase your info on your drive.
Last resort is to wipe the drive clean and reinstall the OS fresh, but this will erase everything.
Before erasing everything, if you have access to a second mac, you can connect the emac to the other mac via a firewire cable, turn on your emac in hard drive mode by starting it while holding down the "T" key. You'll get a firewire icon on the screen. Then turn on the second mac... you can off load any files to the second mac and then reinstall the OS via the OS discs.
Best of success.
k
Sep 18, 2009 | Apple eMac 1.2GHz 256 40GB Combo Drive -...
Ibook g3
First of all, you need an Airport card for the iBook G3, chech for example this link; http://popular.ebay.com/ns/Computers-Networking/Original-Airport-Card.html (you should buy one like this: 9deeeda.jpg
, there is a G4 card too, but your iBook doesn't support this one).
Next, install it;
Then, buy a wireless router that uses 802.11b/g or 802.11b. This is very important because your airport card doesn't support 802.11g, and install it, but don't protect your network with a WAP password, your iBook doesn't support this, but use WEP.
Then start your iBook, and click on the Airport icon in the right corner, select your network, type in the password and it will work!
Jul 01, 2009 | Apple iBook G3 Mac Notebook
Apple eMac Desktop Logo
471 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
