Question about ZoomCam III -USB 1598 Webcam
Zoom pc camera 3808 - ZoomCam III -USB 1598 Webcam
Need a manual for a Vivitar Vivicam 8600s
Generally speaking, zooming reduces clarity. This is already a low megapixel camera at 8.1 MP, with a 6X optical zoom. This means that, for anything up to 6 times the resolution, it'll really zoom in by adjusting lenses.
Everything after that (8.5X) will be digital, which will result in noisy (pixelated) pictures.
However, make sure to take a few zoomed pictures and view them on a PC or Mac with an actual monitor. It's possible that the zoomed pictures only look bad on the tiny screen of the camera itself.
Nov 26, 2014 | Vivitar ViviCam Cameras
The zoom browser does not recognise the camera is connected to PC
Windows updates change the registry. Sometimes this means our connected equipment no longer works. Now it is time for you to start using a separate card reader.
May 17, 2010 | Canon IXUS 80 IS Digital Camera
Camera wont turn on after downloading pictures. I forgot that the camera was still attached to the computer and shut it down. Now the camera is still extended in zoom and does not turn on/off.
Direct downloads from camera to PC are heavy on battery capacity. Remove battery and either replace it with a new one or a fully charged one (note that Olympus recommend Lithium or rechargeable LiON batteries). Press the shutter release once to make sure that it is not in sleep mode.
Make sure that the camera is in "Data Transfer" mode.
Now start the PC, plug in the USB cable at the PC end, and then connect the camera to the PC.  Use the eject/remove function to disconnect the camera.  Now switch the camera to one of the taking modes.  Try to zoom the lens.  If it is still permanently out then you have a trip to the dealer.
Feb 28, 2010 | Olympus D-595 Zoom Digital Camera
Havit 3808
Here is a link to the driver in compressed rar format. Click on the 3808 rar download.
http://rapidlibrary.com/index.php?q=driver+winxp+webcam+havit+3808&filetype=0
If you don't have a rar extractor, there are many free programs on the net... here's one popular one...
http://www.7-zip.org/
Sep 22, 2009 | HP P1978A Webcam
How can i transfer my pictures from C-370 olympia to my pc
I take it you have a cable that goes from the camera to a usb port on the pc.Download Picasa3 from Google and watch your pictures appear....easy
Apr 01, 2009 | Olympus D-535 Zoom / C370 Zoom Digital...
USB PC Camera Havit 3808 SN9C120
i want the driver of havit 3808
Jul 22, 2008 | HP P1978A Webcam
Optical / Digital Zoom
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Turn the Mode Dial to Playback, then press the "T". Use the Enter button to move around the display area. Press the middle of the ENTER KEY to see your images in thumbnail view and / or scroll through several images at one time to find a specific / special image quickly.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Optical vs. digital zoom
It's important to understand this difference, as you could be disappointed with the results if you use one rather than the other. Optical zoom works like the zoom on a traditional film camera. When you push the button to zoom in or out, physical lens elements move inside the camera, reducing the field of view and making the object you're shooting appear closer. Digital zoom, on the other hand, has no moving parts. The camera interpolates a small portion of an image to artificially restore the file to its original size. Using its electronic brain, the digital camera analyzes what it sees and digitally zooms in, usually two or three times closer. Unfortunately, digital zoom also reduces the resolution of an image, so your picture will tend to be more pixilated than the same image taken with an optical zoom camera. If you're just snapping an image to e-mail to a friend, this loss of resolution won't be so noticeable. But in situations where the highest quality counts, skip the digital zoom and use your PC's image-editing tools to zero in on your subject.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
If I take hi-res pictures with the 3040 how much can I manipulate the image on my PC to zoom in while still maintaining quality?
Digital zoom in the camera means nothing. You can't create detail that isn't there. Enlarging and sharpening on the PC can produce much better results than in-camera digital zoom - no more real detail, but a better illusion of detail by enhancing edges. You can print up to about 8x10 with the 2100 or 11x14 with the 3040, but a zoomed in 2100 8x10 will probably be a more spectacular picture than the 3040's 11x14, unless you can get equivalently close to your subject. Also, the more precise viewfinder of the 2100 can make up for the difference in resolution. With the 3040, you are more likely to need to crop to print your desired view (unless you can use the LCD), since you can't see exactly what you are going to get when using the optical viewfinder and will tend to get more periphery than you want.
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
ZoomCam III -USB 1598 Webcam Logo
94 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
