Question about Playskool Busy Ball Popper
Large wooden puzzle pieces stuck and cant be removed without unscrewing . have tried doing this but am unable to . is there somewhere i can have this fixed in NZ ?
Unable to find secret
This level starts off fairly straightforward, so head on out. Follow the save
straight along until you pass through the wooden door. You will come to a
puzzle that you must solve. When you are playing this area in co-op, let one
player do all the work as there is a bug that will make this very frustrating
to complete. You must step on the squares in pairs to make the entire board
light up. You can walk around the board, on it, over pairs you have already
made with impunity, but if you step on something out of sequence, it will
reset and you will have to start over. Once this is done, it will open up the
boulder that was impeding your progress and a cutscene will play.
After the cutscene ends, you will find yourself back in the puzzle tile room
and the wooden door will open. Go this way. The super short level ends here.
Jul 15, 2008 | Sony Untold Legends: Dark Kingdom
HOW CAN i find INSTRUCTIONS for CREATOLOGY wooden puzzle flying dragon?
Hi, if you cannot find instructions just google for images of the puzzle and print off, just as good maybe. Sorry if I have misunderstood the necessity, is it just for reference in order to complete puzzle?
Good Luck
PS there appear to be several images available
May 28, 2015 | Puzzle Toys
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
Hi, I am trying to change right rear tire on lexus LX470 1999 model, but after unscrewing the tire bolts I can't remove the tire off. Am I missing something ?
yes aluminum rims? if so your aluminum rims ahve vulcanized themselves to your stell brake rotors. this happens with dissimilar metals. only force and heat will make it come off. you can try yourself or have a shop do it. at home jack up car , remove lug nuts. place car on jack stands with the offending wheel in the air. you will have to throw a large heavy solid wooden block to dislodge the stuck wheel. it is not easy or pretty to do.
Jan 02, 2010 | 1999 Lexus LX470
Wooden piece puzzle square/rectangles various sizes coloured dots
it's okay I ended up finding the instructions. thanks.
Dec 23, 2009 | Puzzle Toys
How do you assemble the pineapple wooden puzzle
I have this puzzle and I am so Confused! It is really hard but I enjoy trying to put it together
Oct 11, 2009 | Puzzle Toys
Jammed washing machine filter
It is stuck because there may be something stuck in the filter, or it is the rubber seal that has expanded, try levering it out with a screwdriver or something like that, or if there is something you can grip with a pair of grips or pliers ,try pulling it out that way.
Plz rate solution.
Thanks
Dec 26, 2008 | Samsung Washing Machines
Paper stuck in brother printer
Which model printer.
Some printers have levers to disengage the traction to enable gently removing the jammed paper.
If you cannot remove it easily and it happens to rip try a trick I learned at a printing company: Re-construct the paper like a puzzle and dont stop looking for small pieces of ripped paper untill the puzzle is complete.
Good Luck.
May 02, 2008 | Office Equipment & Supplies
BROTHER MFC-3240C
The printhead cant travel without prob in its rail. Try to pick up the paper which might stuck somewhere.
Oct 22, 2007 | Brother MFC-3240C All-In-One InkJet...
Playskool Busy Ball Popper Logo
32 people viewed this question
Top Playskool Toys Experts
ray gallant
Are you a Playskool Toy Expert? Answer questions, earn points and help others
