Question about Yamaha RX-V596 Receiver
Yamaha rxv 596 is shuting down after few minutes
5 Suggested Answers
SOURCE: Won't power up
Its a consideration....I will let you know.
Posted on Mar 07, 2008
SOURCE: Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Posted on Oct 30, 2008
dunnbiker
  • 8546 Answers
SOURCE: my yamaha rxv 650 volume
yes it is
Posted on Apr 06, 2011
Testimonial: "thanks very much"
  • 436 Answers
SOURCE: Yamaha RXV -657, the amplifier switches off on its
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 29, 2011
How do i reset rxv-1300
There will be a specific procedure found in your owner's manual that you must follow. It may say reset, or return to default. If you don't have the manual, you can find it on Yamaha's website.
Dec 21, 2014 | Yamaha Audio Players & Recorders
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
When turning the source selector on my AX-596, is sometimes takes a couple turns for it to change source. Is this an easy fix? dirty switch?
remove the front panel and if you have clear alcohol and just few times over the SW and turn it around that's all
just tell me if it work
Aug 03, 2011 | Yamaha AX-596 Amplifier
change + to - or
Oct 30, 2008 | Yamaha HTR-5730 Receiver
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Jul 27, 2008 | Yamaha AX-596 Amplifier
Yamaha RX-V596 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
