Question about McCulloch Heavy Machinery
Won't start i switch it to start and turn on petrol but just wont start!
Bike wont start and white smoke from under petrol tank
Hi, Anonymous you may have fried an electrical component and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
TROUBLE SHOOTING
Troubleshooting No Start Honda Motorcycle
Feb 23, 2016 | Tank Motorcycles
Why engine runs when ignition is off
gas or diesel.?
what engine, option. they have names and all are different.
is it CARB engine, or EFI? (below is EFI answer) ONLY.
3 possibles. (gas, otto cycle enigine)
1: key switch bad.
2: relays bad. (stuck on)
3: wiring hacking by goons. (too common)
try posting the engine on car, we can not help ,not knowing that 1 fact.
and year.
below is the vast numbers of engines used, on all B gen cars.
as you can see, we are totally helpless to help. with this fact.
post VIN number
if no vin, post chassis tag dead, under ENGINE statement.
Jul 06, 2014 | 1987 Opel Corsa
Won t start
double anon posted. and this time no year.
ah but you cleaned it and now it dont run
sure,
well we can not guess all the things you did wrong. or forgot.
if you used a pressure washer , (bad that) then you have water
were water dont belong. think so?????
or put back wires wrong or for got to connect , some connectors.
if UNSTATED engine has spark wells.
they are full of water now and spark just hates to be underwater.
93 swift. what engine.??????????????????????
1.3 L M13A I4 (petrol)
1.5 L M15A I4 (petrol)
1.2 L K12B I4 (petrol)
1.4 L K14B I4 (petrol)
1.6 L M16A I4 (petrol)
1.3 L Multijet I4 (diesel)
Jun 27, 2014 | Suzuki Swift Cars & Trucks
Switch to gas
check the solenoid on petrol line from fuel pump to carburettor is switching off petrol to carburettor when switching, you should hear the solenoid clicking when operating. Alternatively you can disonnect pipe fueline at carburettor, turn key ,if petrol comes out of line make sure it shuts off when you turn switch from petrol to LPG
May 06, 2014 | 1997 Ford Falcon
Ran out of petrol started shaking and cutting out now wont start at all
you have probably got a blockage in either the fuel filter or carb,so first check filter,if ok check carb.take fuel line of carb turn engine over see if fuel comes out if it does then filter ok if not change filter,
Dec 28, 2011 | Cars & Trucks
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Having trouble ulocking fuel cap on yamaha r125
Hi, Angieblackst for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Petrol Cap Wont Come Off Key Won Turn At All Tried Wd40 Oil Etc Still No...
Stuck Petrol Cap
Yamaha YZF R125 Service Manual
OEM parts for Yamaha
YAMAHA YZF R125 Owner Manual
May 14, 2010 | 2008 Yamaha YZF-R125
Wont start
charge battery, then check if you are getting a spark, remove the plugs and let petrol dry out of bores, if you are getting spark should start
Feb 27, 2010 | 2006 Triumph Speed triple
Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Jun 27, 2009 | Garden
Heavy Machinery Logo
42 people viewed this question
Top McCulloch Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a McCulloch Heavy Machinery Expert? Answer questions, earn points and help others
