Bluestar split ac error code f1
What does it mean by F1, do any one know where to get all erorr code listing, I tried the user manual given by company and typing in google, no luck.
SOURCE: error code c4
Indoor gas pipe thermistor faulty.
Posted on May 06, 2008
duby1990
  • 370 Answers
SOURCE: Frigidaire FCS388WHCC. F1 error on
leave the breaker off for 10 minutes and see what happens. A lot of times that will reset the clock and it will start working.
Posted on Nov 18, 2008
SOURCE: F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Posted on Apr 11, 2009
  • 492 Answers
SOURCE: whats is the f1 code mean on the dash
Go here and read the forum: http://www.gixxer.com/forums/showthread.php?t=174828
Posted on Apr 30, 2009
  • 19 Answers
SOURCE: I have a split type LG ac and I the remote control
A problem that almost everyone gets but what happens is that sometimes we have notice the remote if the screen looks dim or if it has rust in the battery compartment these are signs of your remote getting worn and also depends on the age of the unit the piece that is right infront the reciever gets taint so it blocks the eye and it seems like the remote is not working just look into it when servicing
Posted on Nov 06, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Soleus dual mini split KFMHP18 fault error F1
    F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
    Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
    Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
    The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
    Gene
    Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
    What does F1 error mean?
    Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
    Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
    Nov 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
    Hi.
    The error meaning depends on the oven brand.
    On Amana and other brands F1 is a faulty control pad or faulty electronic control.
    That may be your case , since the electronic control looks being jammed.
    Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
    Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
    Regards.
    Mar 02, 2010 | Ovens
    My machine stops and blink f1
    unfortunately the only thing you cud look for in errors in washing machines is whether the door is closed properly or not. beyond that u will hav to look for a service technician the codes can be deciphered only by a service technicians of that particular company as error codes differ from company to company. The only thing I cud say is that there is a malfunction of one of the components in the machine sorry but if u hav the manual see if the error code u mention is listed in the manual
    Aug 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code on Kenmore Oasis He
    I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
    May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    Apr 11, 2009 | Fisher Dishwashers
    GE ADVANTIUM 220 VOLT
    hi,
    F1 usually means the board is bad. this may be different but I would call back the repair company that replaced the board.
    Mar 30, 2008 | Microwave Ovens
    Heating & Cooling Logo
    720 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
