Question about IBM Lenovo ThinkCentere M51-8141
ACPI\NSC1100 need solution for this device in win 7
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Computers & Internet
Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
Oct 24, 2013 | Computers & Internet
Toshiba c650 repair manual
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Aug 26, 2012 | Toshiba Computers & Internet
IBM M51 8141,NO DRIVER FOR ACPI / NSC1100, my System win7 64 bit
Hi Darius...
IBM M51 8141 ACPI / NSC1100 drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Aug 22, 2011 | IBM Lenovo ThinkCentere M51-8141
My multi touch pad is not working. how can i redeem it again?
You need to go to ASUS's website and find their downloads in the support section. You need to use the chipset, touchscreen, and acpi drivers. The XP drivers will work in win vista and windows 7. You will also want to get the elantech touchpad configuration utility from them. The chipset and acpi drivers will also make your function keys work.
May 07, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I need to install win xp on hp 540 and ineed to know if i have to configer from bios or i need win xp sata support OS?
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
Jan 08, 2011 | HP Jornada 540 Pocket PC
My aus f80 q the keyborad fn key not working with win 7
Install the following Windows 7 drivers and utilities.  All the function keys will work properly.
ATK0100 ACPI Driver
ATK_MEDIA Utility
ATK_Hotkey Utility
ASUS ATKOSD2 Utility
ATK Generic Function Utility
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K50IN
Dec 10, 2010 | ASUS 90-A4C1K1000 Keyboard
Hello, i've got a problem acpi windows seven ms8137c+
Is this Mother board Windows & compatible?
Check at the Microsoft knowledge base and see if *********** board meets the specifications.
this board according to the specifications may not be compatible with Windows &
Windows 7 Requires at 2GB of ram.
Apr 01, 2010 | Computers & Internet
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Win xp didnt detect new processor
Go into device manager and uninstal "acpi multiprocessor" (in computer tab) and reboot and cpu should be detected properly.
Hope that sorts it for you? :)
Jan 04, 2008 | AMD Athlon 64 X2 4200+, 2.2 GHz...
Computers & Internet Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
