Question about ASUS Computers & Internet
Dumping error problem error dumping
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Solution
Step 1: Check Recently Installed Hardware and Device Drivers
It has been found that many times BSoD occurs because of a faulty device driver or there is a conflict with the recently installed hardware. In such cases, try the latest version of the driver and reinstall the hardware, but before that make sure the hardware is compatible with your system. To pinpoint the problem, you can use third-party software to disable a recently installed driver and see if the problem is solved. Sometimes the problem also could be that the device driver has not been properly configured to meet the requirements of the system.
Step 2: Repair Your Registry
The second most common cause of BSoD is a Registry that has become corrupted or has a lot of invalid entries. If you are experienced and knowledgeable about the Registry, you can edit it yourself, but this is always a risky proposition, and the best course of action would be to buy special software which automatically scans and fixes problems in the Registry.
Step 3: Check CMOS and Memory Modules
If the error message on the BSoD reads "UNEXPECTED_KERNEL_MODE_TRAP," then it indicates you have problem with the memory of your computer. You need to check whether the SIMMs (Single Inline Memory Modules) are compatible and have the same speed. Secondly, also check whether you have set the CMOS (Complementary Metal Oxide Semiconductor) to the right amount of RAM. If these solutions do not work, you might have to replace memory in your computer.
Step 4: Rectify a Damaged Hard Drive
Sometimes the cause of BSoD is a faulty hard disk. Most Windows operating systems have a diagnostic scan for the hard drive, and you need to run this to figure out the problem. Sometimes the operating system will encounter a problem where it is unable to read from the hard disk, and in such cases apart from the hard disk, you also need to check out the SCSI (Small Computer System Interface) terminator.
Step 5: Scan for Virus
BSoD problem can also be caused by a virus which has infected crucial files in the hard drive that might disrupt the flow of information between the operating system and hard drive. If you have already installed antivirus software, you might have to scan your computer with a new one.
Posted on Apr 15, 2014
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
Ibmr60 gives dump error
could possibly be faulty RAM, try removing and reseating or try another stick. dump errors can be caused by many different things. the system could be overheating, a peice of software/driver could be incompatible/corrupted. try starting the system in safe mode, if you can it is probably a driver issue, you could then check device manager to see if there are any driver errors, you could also run chkdsk for hard drive errors
Mar 09, 2012 | IBM Lenovo ThinkPad R60 Notebook
I have a Creative Live ! Optia AF Webcam. If i put the USB of the Webcam in the USB-Slot (1 of 4 USB-Slots and all tested), i get a Bluescreen Error and my Computer shuts down. Is my Webcam destroyed? The...
A bluescreen error is rarely a good sign, but sometimes it's fixable. Have you tried plugging the webcam into a different USB port? Also have you tried unplugging some unnecessary USB devices and then using the webcam? You may be draining too much power from the PSU with USB devices and the PC shuts down to prevent damage. Have you been able to test on a different computer to see if the problems happens there as well?
Mar 24, 2011 | Creative Labs WebCam Live!
Hello. Could you tell me, please, what "error 8006" displayed at Epson AcuLaser C1000 means?
Error 8006 is a general message that Adaptive Server can raise in a number of situations when working with another Sybase server. The "%S_MSG" in the message text is the name of the server that generated the error.
Most commonly, this error indicates that Backup Server encountered a problem in running the dump database or load database commands. When you issue a dump or load command from Adaptive Server, the server interprets the command and sends remote procedure calls (RPCs) to the Backup Server. As dumps and loads execute, Adaptive Server and Backup Server use RPCs to exchange instructions and status messages. Thus, an 8006 error during a dump or load is typically accompanied by additional messages originating from the Backup Server.
Jan 31, 2011 | Computers & Internet
Pc dump error while windows installation
I believe pc dumping errors may refer to memory related problems,try using different or new memories,also use another installation disk
Sep 18, 2009 | Computers & Internet
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Blue screen
hi daget200;
can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
Jun 07, 2008 | Computers & Internet
Blue Dump error "0x05001309"
what does this have to do with winfax?
May 09, 2008 | Symantec WinFax Pro for PC
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
