Question about Samsung Washing Machines
How to open the front of a samsung J1043 washing machine
SOURCE: I have a Samsung J1043
I rewashed the clothes a couple of times and finally the door released.
Posted on Oct 02, 2008
barkencoa
  • 3463 Answers
SOURCE: Jammed washing machine filter
It is stuck because there may be something stuck in the filter, or it is the rubber seal that has expanded, try levering it out with a screwdriver or something like that, or if there is something you can grip with a pair of grips or pliers ,try pulling it out that way.
Plz rate solution.
Thanks
Posted on Dec 26, 2008
  • 22 Answers
SOURCE: washing machine not draining or spinning. samsung
Samsung washer drain pumps usually have a trap that may be holding a large amount of debris (buttons, pins, coins, etc) and lint packs around all of it and the water can't drain, which means the unit won't spin. A more complete model number would be required to find out if the trap is accessible by removing the front panel or not.
Posted on Apr 25, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Posted on Jan 31, 2010
Have a Samsung J1043. doesn't wash no spin.
Go to www.repair clinic.com and enter J1043. You will be presented with a list of common repair parts and may be able to view a general disassembly procedure for Samsung machines.
Jun 03, 2016 | Samsung Washing Machines
Need to buy a circuit board for samsung front loader J1043
you should be able to contact samsung parts department and purchase it through them or they can give a name of a distributor they also deal with marcone appliance parts.the part number you nedd according to your info is dc92-00200b main pba assy
Jun 09, 2010 | Samsung WF203ANW Front Load Washer
Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Jul 07, 2009 | Samsung WF337AA Front Load Washer
Washing machine not draining or spinning. samsung j1043.
Apr 25, 2009 | Samsung WF203ANW Front Load Washer
4e code
I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
Hope this helps.
Dec 26, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
