My Digidoor 2 opens halfway and then gets stuck. If I do activate it to open again , the motor runs but ithe door does not open.
SOURCE: Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem with the worm gear shaved. I bought the replacement part and replaced the worm gear. The door did not travel to the full distance between the limit switch. It hit the upoer limit, stopped. When I pressed the remote again, it only reverse for a short distance and never hit the other end of the limit switch. Any hints what the problems are?
Posted on Jun 12, 2009
blanchettohd
  • 143 Answers
SOURCE: Digidoor 3 garage door only opens about 60cm and
The problem might actually be the door itself. make sure it raises and lowers easily and is well balanced. If it is then find the power adjustments and turn up the up force to work the door. Do a 2x4 safety reversal test afterward. Thanks BB
Posted on Sep 03, 2010
blanchettohd
  • 143 Answers
SOURCE: I bought a second hand Digidoor 1 with garage
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Posted on Sep 22, 2010
  • 1340 Answers
SOURCE: I have a Liftmaster 2000sdr 1/2 hp garage door
The extra light wired in should not affect your door open to that extreme unless there is a cross wired connection,bad connection,or some kind of wrong wiring when it was installed.If this started the very same time you had that light installed,you definitely should have that checked.A flourescent light is such a low power requirement,it would be similar to plugging in a little 4 watt bulb night light into a socket and popping the circuit breaker.However,if the light was so badly wired,it would more likely cause the circuit breaker to pop.You really need to make sure that both lights are in the same circuit.It sounds like you had the new light installed by a pro?If you did,your door opener is the most likely problem.As far as the error code,the sensor could easily go bad causing the motor to overheat or the motor could simply be overheating.If you want to self-repair,I am sending a parts diagram link which I found,which the breakdown is near the bottom of the entire download.You need Adobe.It is a free,safe download with no junk pop-ups ever.Most people know but i always include it.The cheaper,easier attempt to fix is the RPM sensor.If you can't read parts diagrams,the pictures are quite accurate although assembly/disassembly of them is not always.This particular one is pretty common as far as on-line quality which is so-so.There is not much comparable to seeing the manufacturer's book in person.Every part you remove,put it in an order and in a manner in which you can remember for re-assembly.Maybe even take pics with a digital camera as you go step by step.If you are unsure about anything,take pics of the same part from a different angle.I am starting post this because I have seen quite a few problems where the person says I took such and such apart and a spring popped,pieces flew,how do I put it together?To find a parts diagram posted downloadable free by a manufacturer is quite rare.Cell phones aren't as good for pics.If you want to,I would even help you over the phone.There is also 2 parts attached to the motor which are called pulleys,they look like they have gear teeth on the diagram,which is what they basically are.If they are metal,they would not likely strip but since everything is plastic these days,they could be plastic and stripped.There is also a belt attached to those which simply may be stretched,overworking the motor and overheating.Since you seem to have had the problem happen several times,the motor probably still is good.I would avoid doing it too much before you do fry it though.So all this stuff is worth at least a look as long as you find out your light is wired properly or not on the same circuit.The RPM sensor is part 12,the motor is part 8.If you end up having to do the motor also,there are also other sub-parts under part 8 which I would also buy no matter what.The clicks does sound like a relay attempting to enable the circuit.If you need more help or have a question or need some talk through,just comment here and I will get an autolink and reply ASAP.
Good luck! Greg
http://www.bearcatco.com/PDF_OPENERS/Liftmaster/2000_1000_SDR.pdf
Posted on Oct 18, 2010
swolfinor
  • 504 Answers
SORRY TO SAY IT SOUNDS LIKE A FRIED CIRCUIT BOARD. LEAVE THE UNIT UNPLUGED FOR AT LEAST 30 MIN. & TRY AGAIN, IF SAME RESULTS I WOULD REPLACE THE BOARD.
HOPE THIS HELPS
Posted on Nov 10, 2010
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
How do I program a Digidoor 3 garage motor.
Limits must be programed. Power down and remove battery power ,press & hold button on motor pc board then apply power still holding button. The door should start running open and close. When it starts you can release button
Oct 31, 2014 | Building Materials
How to re programme my Digidoor III garage door motor?
Did you check it engages the end switches?
Oct 07, 2014 | Building Materials
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
Door closer problem
Your description sounds like a sensor is malfunctioning. the close sensor needs to be slightly LESS sensitive, based on your "assistance" description.
Jan 28, 2012 | Cars & Trucks
I have a Digidoor garage door that closes halfway and the opens again however when you apply a little pressure to the door the door closes completely The entire shaft was cleaned and lubricated but still...
There probably is a dent along the shaft either in the remaining region or the already occupied region. You should open it completely and verify that the shaft is uniform. There could also be a deformed roll in the part of the door that enters the vertical part of the shaft around the time the door stops closing.
Nov 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi, My Digidoor II opener only moves the door 20mm at a time and stops. The same happens using the remote or the wall mounted pushbutton. How do I fix this?
I had the same problem easy to fix!
It's the rocker rail (small plastic thing that ajusts the power and direction) that is damaged. Buy the part for R36-00 from any Digidoor agent 011 3978448.
Remove the motor from the installation rail and open the blue motor cover. You will see the rocker rail is attached to the blue cover, one of them will be broken. Replace both of them (up and down)!
Jan 06, 2011 | Computers & Internet
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
1999 Nissan Altima window won't go up -stuck. don't know if it is a motor or a mechanical issue. Window got stuck halfway down for 2 years but could pull it up and motor worked, but not now. Any...
If you don't hear the motor running anymore it has stopped working or jammed. If the motor is running it maybe something as simple as a track that needs replaced. You will need to open the door panel to find out and repair this. I recommend you get the Haynes repair manual to do this.
Dec 12, 2009 | 2003 Nissan Altima
 Grubhead
Grubhead
