Question about Konica Minolta bizhub Office Equipment & Supplies
Toner peeloff after printing - bizhub Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 3,497 Answers
This would be caused by a faulty fuser unit if this is a laser printer. The toner requires about 400 celcius from the fuser unit to fuse to the paper .
Posted on Apr 15, 2014
  • Dax Estorioso
    Dax Estorioso Apr 20, 2014
    It's the fuser film, not your toner. You need to replace it. Have it serviced by a technician.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Life time of ricoh 3002c drums
Toner BK
Print Cartridge Black
Bla 841647
28,000prints/bottle*
Toner Y
Print Cartridge Yellow
841648
18,000prints/bottle
Toner M
Print Cartridge Magenta
841649
18,000prints/bottle
Toner C
Print Cartridge Cyan
841650
18,000prints/bottle
Feb 29, 2016 | Ricoh Office Equipment & Supplies
My hp1012 is printing dark with shading on the pages and shadow or echos. Can something be replaced or fixed?
with this issue, you pretty much have to run a half way test unless you have the convieniance of another toner to try. basically, it's either going to br your toner or your fuser and a halfway test will determine this if you don't have another toner to try.
The Half-way Test
You will need to print a page and open the toner lid when you think the paper is underneath the toner cartridge. This will stop the printing so you can pull the toner cartridge out and look at the partially printed paper. It may take a few tries to time this test correctly so the paper stops under the toner but not completely into the fuser.
1. Print a test page from Tray 1, the "fold-down" Multi-Purpose tray on your printer.
2. Just as the test page completely disappears into the printer, open the toner lid door. The print job will stop, sensing an error.
3. Pull the toner cartridge out, and you will find the test page sitting directly underneath the toner.
4. Carefully remove the page by gently pulling the page upwards & free from the toner cavity. Careful! The toner has not yet been fused to the paper, so the print can be somewhat messy on your hands and may smudge easily.
Examine the printout.
1. If you do not see the print defect on your test page, that means the defect is being added later in the print process by the fuser. Fusers are the main component in a maintenance kit; click here to view our selection of maintenance kits for various LaserJet printers.
2. If the print defect is visible on this printout, that means the print defect is occurring before the fuser. Try replacing the toner cartridge (click here to view our selection of toner cartridges).
If you determine the print defect is occurring before the fuser, and swapping toners doesn’t fix the problem, there could be several things causing the problem. In the order of most likely to least likely: you could have two defective toner cartridges, the transfer roller might be faulty, the laser scanner could be dirty or defective, or the high voltage power supply could be bad. You might want to email or call since these scenarios are not as common.
Order Fuser Here!
Order Transfer Roller Here!
hope this helps and if so please mark FixYa!!
Jul 24, 2010 | HP LaserJet 1012 Printer
BW print OK Color print has 'smudge' as well as print.
Sounds like you have color toner contamination in the print engine, It could be the toner cartridges spilling toner, or cleaning modules, take them out carefully and clean them, it also could be the waste toner bottle needs emptying. Take care not to inhale toner particles.
Jan 11, 2010 | Lexmark C510n Laser Printer
Toner is not out of ink but it lights up, refusing to print
In most cases cartridges have a special chip that remembers the toner cartridge serial number an amount of pages printed from it. This means, that even though there still might be some toner left in the cartridge, the chip's counter reaches it's predefined limit and informs printer, that the toner has run out. Just like that, suddenly.
It may also be the case, that the chip loses contact with the printer's electrical terminals - try reseating the cartridge in the printer. If that doesn't help, it's time to replace it I'm afraid.
Usually the printer will inform "toner low" for some time before it becomes "toner out" and refuses to print. If you get "toner low", then it's time to purchase a new cartridge to have it ready.
Oct 27, 2009 | Fujitsu Office Equipment & Supplies
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
My SF 560PR Printer wont print and displays toner exhausted
Replace it with an original toner cartridge. That could help.
Jul 09, 2009 | Samsung SF-565P All-In-One Laser Printer
Toner Low And it is not printing
Have you changed the affected toner? Most printers will stop printing when one toner is showing empty.
Jun 23, 2009 | HP Color LaserJet 3500 Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
95 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
