Question about Konica Minolta bizhub Office Equipment & Supplies
Toner peel off - bizhub Konica Minolta Office Equipment & Supplies
    New Friend:
  • 78 Answers
If toner is rubbing off ,then you need to replace fusing unit.
Posted on Apr 26, 2014
My brothers printer 2170w has toner sprayed all over in printout
Three possibles for this.
1 A faulty cartridge dropping toner on the paper as it passes through the drum. - remove the toner cartridge and look for lots of loose toner in the drum.
2 The drum cylinder is dirty and needs to be cleaned with alcohol and a cotton ball. Toner can build up on the drum cylinder and also the cleaning brush inside the drum assembly. These would need to be cleaned - or replace the drum. And 3 progressively either or both of the above two may have lead to a build up of toner on the fuser at the back of the machine. In very bad cases the teflon type coating on the fuser may have peeled. If the fuser is dirty, it can be removed and cleaned. If it has become damaged - forget it, just buy a new machine.
May 19, 2014 | Brother HL 2140 Laser Printer
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
The ink is peeling off the laser crystal clear labels. Why? My printer is a HPlaserjet 3050.
Are you using orignal HP cartridges or remanufactured cartridges? We have had a lot of problems with 3rd party toner not bonding properly and installing an original HP cartridge usually fixes the problem.
May 04, 2011 | HP LaserJet 3050 All-In-One Printer
I have a Dell 3130cn that consistantly has peeling toner on any type or weight paper and of course that causes black toner "slobbers" on the back of the next sheet. What the heck is going on? I...
hi there
thats an expensive printer -- you desrev some answers, direct from their techsupport
The printer is new, you should get in contact with Dell, as its under warranty
if dell has inconvenienced you that much, i would ask for free toner cartridge or something of value to compensate : they usally do that for customers
review the firmware information for the printer , see if you have the latest version, if not go to this link to download
http://support.us.dell.com/support/downloads/download.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&releaseid=R269308&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=396303
may this serve you well !
Nov 04, 2010 | Dell 3130cn Color Laser Printer
Sir, I am getting black patch on right side of the paper when I take xerox. Please reply
is these black patch like the toner isnt baked and it peels of the paper?
If yes, you have problem in fixing section, probably fixing rollers bushing.
Also remove the drum unit and check drum for toner leftovers. If the drum is covered with toner after copieing replace drum unit.
Hope that helps!
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Get code 004 332 restart printer. have removed the four toner cartridges and replaced the drum cartridge and the same code appears
Hello,reseat and clean the four toner cartridges, verify the orange plastic covers have been removed, and verify the cartridges are fully locked into place, .This is the procedure:
1. Press the Menu button and press the down arrow until Replace Toner appears, and then press the "ENTER" button.
2. Press the down arrow to choose the appropriate color toner cartridge and press the "ENTER" button.
Note:If the Menu button is inaccessible, begin replacing the toner cartridges with step number 3.
3. Open the front cover.
4. Lift the handle of the appropriate colored toner cartridge and remove the toner cartridge.
5. Gently rock the toner cartridge from side to side.
Note:Rock the toner cartridge over newspaper as there may be some toner leakage.
6. Gently wipe the exterior of the toner cartridge with a dry cloth.
7. Verify the mag roller has been removed.
Note:Grasp the orange strap, peel the tape away from you, and then, with the tape free, pull the blue strap toward you.
8. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place.
Note:Ensure each cartridge lever is fully pressed down into the locked postion.
9. Close the front cover.
10. Repeat steps 1 through 8 until all toner cartridges have been reseated.
Good luck
Feb 05, 2010 | Dell 3100cn Laser Printer
Hi, I have a Ricoh 1224c, color copies come out with a blurred or waterfall effect on about the first half inch of the leading edge of the copy, but the black copies are ok. The next 1 1/2 inches roughly...
The Colour toner more small and he does not disappear the blade a peelings, you it is necessary to check the magnetic hand on colour cartridge. If hand unevenly covers the magnetic gross to adjust the дозирующее blade. Clean the gross, insert the sheet of paper between dose and gross and release the bolts an dose blades, press the blade to paper aside gross magnetic, afterwards bolt the bolt. Extract the sheet. Clean all from the remainder of the toner. Check the blade a peelings drum if evaporation during stop main by breaker exists on drum, change rakel. The Period of rakel's work is measured by period of the work photo drum, beside 10 thousand sheets. Such effect more often exists from wear-out of rakel. Remind, black toner has grain more so he leaves the rakel. The Colour toner small and its clear requires new rakel.Udachi. fault has not an electronic reason. This mechanics.
Oct 06, 2009 | Ricoh Office Equipment & Supplies
Where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Apr 08, 2009 | Kyocera Copystar CS-1820 Black and White...
HP Color LaserJet 2600n toner problems
In speaking with other tech support people it appears my image drum needs to be replaced. Also sounds like it will be more economical to buy a new printer.
Feb 19, 2009 | HP Color LaserJet 2600n Printer
CLC 1100 toner peeling on 11 x 17 pages
Try to do Auto Grad. You push the button (additional functions) next push ( Grad. A Adjst ) and just follow what the copier tell you to do.
Jan 29, 2008 | Canon CLC 1120 Color Copier
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
