Question about Janome Mini Compact
Jl mini faceplate
My daughter has lost the face plate from her JL Mini sewing machine. Any idea where I can get a replacement?
  • Paul Fleming
    Paul Fleming Apr 25, 2014
    Janome responded very quickly when I emailed them & the 'slide plate' is now on its way albeit with postage more than the value of the part itself
  • SE Looper
    SE Looper Apr 25, 2014
    That's great. I hoped that they could help.
    Problem Solver:
  • 15 Answers
Have you checked the website for this machine? They should be able to direct you to a replacement plate. I hope that this helps.
Posted on Apr 17, 2014
SOURCE: feed dogs on my machine wont rise above plate
Open the door infront of the hook race assembly/bobbin carrier and check to the right of that. There is a chrome lever which engages with slots in the plastic casing. The correct position for this is as far to the left as it will go. If it is to the right furthest extent it will disengage the feed dogs. It should disengage automatically but if has not, press the lever down and slide it to the left. Good luck
Posted on Apr 27, 2007
  • 106 Answers
SOURCE: Have no instructions for janome sew mini
Have a look at this website, if you machine is not listed email them and they will help, it will cost for a manual but very little is free these days.
www.sewusa.com
Posted on Apr 02, 2008
mallow1
  • 35 Answers
SOURCE: Accessories for the Janome Mini Sew
Almost all of the Janome feet are interchangeable. Only a very few of their higher end electronic machines have special feet. So, if you ask for Janome feet, in general the stores give you the general purpose feet that work on most mechanical Janomes, such as Jem Gold, Decor, etc. Hope this helps!
Posted on Aug 16, 2008
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
wcbotha
  • 92 Answers
SOURCE: Won't sew
Give more info. Do the motor turn? is the machine stuck? or do every thing work but it do not sew onto the material? We got 9 machines that we work with every day and we repair it as well. E-Mail me and give more info and i am sure I can help. Willem an Fienie South Africa ( wcbotha@yahoo.com )
Posted on May 12, 2010
Where can I fine replacement parts for style elements sewing machine model no. JL-6?
This is a bargain priced sewing machine from China.
http://www.chinatexnet.com/ChinaSuppliers/22631/JL-6-Crewel-2-Speed-Table-Sewing-Machine-192756.html
You're probably money ahead to just buy another. They offered on the Internet:
Google
Mar 18, 2015 | Sewing Machines
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Upper thread not engaging bobbin thread...
Hiya Kandie. Usually when you can't pull the bobbin through, the wrong size needle is in, try a different size needle. Hope I was some help for you.
Feb 08, 2012 | Janome SEW MINI Mechanical Sewing Machine
How do I change a needle on a Janome jl-634
The jl-634 is a serger so should have two needles. There are two small screws (one on the left and one on the right) of the needle bar. First raise and remove the presser foot (makes changing the needle much easier) Rotate the needle bar to its top most position. Loosen the small screw for the needle you wish to replace, do not unscrew it entirely as it is finely threaded and difficult to re thread. Remove the needle while observing the orientation of the shaft (which direction does the flat side of the shaft face) Insure that replacement needle is correct for your machine. Serger needles are usually different from standard sewing machine needles. Insert new needle with correct orientation, and re-tighten the small screw previously loosened. Reinstall and tighten presser foot. Rotate machine through entire stitch cycle to insure that needle does not strike or rub on anything. Re-thread needle and check for proper operation.
May 06, 2011 | Sewing Machines
Light bulb not working
You need to change the bulb.
Most light bulbs in almost all sewing machines are located inside the face plate on the left hand side of the machine.
The faceplate is usually hinged at the back and it opens a bit like a door. It should open fairly easily and close with a click.
Open the faceplate and unscrew the bulb, it should be in plain view.
Look to see if it a screw or bayonet type.
Replace it the same way you would an ordinary bulb.
You can get sewing machine bulbs on ebay but you'll need to know which type of fitting it has before you buy.
Hope this helps!
Nov 10, 2010 | Singer 7462 Mechanical Sewing Machine
Janomes sewing machine bobbin
Hi. Check to make sure the needle is in correctly. There is a flat side on the needle shank and that has to be facing a particular way. For most modern machines, the flat side of the needle faces to the rear, away from you, but it's always a good idea to check the manual to make sure on your machine. If the needle is bent, that can cause the same thing, but it's almost always that the needle is in wrong.
Happy Sewing!
Robbie
Apr 16, 2010 | Janome Mini Compact
Need new faceplate
you can actually smooth you needle plate you have with a emory board , a small file or sanpaper. Just smooth the jagged edge-quick and cheap
Mar 18, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Jan 31, 2009 | Elna 2007 Mechanical Sewing Machine
Janome Mini Compact Logo
43 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
