Question about Tally 6306 Matrix Printer
On print command error showing "print fault stb cnt=1" on the printer front panel. if press the cancel switch it is showing hammer voltage 1
SOURCE: hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Posted on Jan 04, 2008
zhupeilan123
  • 6 Answers
SOURCE: fault hammer voltage 1 problem facing in lipi 6306
it is good.
We are always here to serve your needs and provide quality service. Ourproducts range include replacement computer batteries for most majorlaptop brands, including Dell, Apple, Compaq/HP, IBM/Lenovo, Fujitsu,Gateway, Sony and Toshiba. <a href=http://www.bestlaptopbattery.co.uk>laptop batteries</a>
Posted on Apr 15, 2010
LineMatrix
  • 34 Answers
SOURCE: Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Posted on Apr 26, 2010
SOURCE: problem for lipi 6312 tally genicom line printer
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Posted on May 19, 2010
SOURCE: the 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Posted on Jul 05, 2010
I have a taly t6215,for about 7 years it worked with no problem.but it's about 1 week that when we print it shows an error message like this:"...voltage".when I turn it off and then turn it on it work
You are most likely seeing "Hammer Voltage" errors on the T6215, it is worth observing the exact wording of the error seen as this can identify the cause. If the error is Hammer Voltage this indicates there is a problem with one of the following components; One of the hammer coils may be faulty, try a meter across each coil to measure its resistance a faulty coil should show up as being different to the majority. There may be a short circuit to one one the hammer coils, ensure the ribbon shield is not damaged and is in possition correctly, also ensure there are no foreign bodies which may short across the hammer bank. Check the ribbon cable from the main board to the hammer bank for damage and ensure the cable connects correctly. There may be a fault with the main board or with the interconnect board on the hammer bank.
Nov 12, 2011 | Tally T6215 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Hammer Voltage 1
Hammer Voltage 2
Corrective Action:
Apr 05, 2010 | Tally T6218 Matrix Printer
ERROR 016-720 FOR DELL
The problem correspondent to this error code is: "Error relating to PCL emulation problems occurs."
The solution is: · Press the "Return" buttonto clear the message, cancel the current print job, and conduct the next print job, if any. Press Cancel to cancel the print job.
Mar 30, 2010 | Dell 3100cn Laser Printer
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
Dec 13, 2009 | Tally 6306 Matrix Printer
Start Up red light error 37,004.40:35596
That is a Jet Heat error. Most likely a bad print head. Could be the electronics module.
Either the print head heater has failed, or the supply voltage to the print head heater.
Either one is very expensive to replace.
May 30, 2009 | Xerox Phaser 8400DX Thermal Printer
My epson stylus color 670 prints goobley gook
Many older printers want to finish a print command before allowing resetting to normal printing, and will ignore your cancel print command in My Computer/Control Panel/Printers/Properties. So either let it finish by feeding used paper or unplug it, cancel documents and then plug it in with the power and feed buttons pressed at the same time to reset. If it will still not print normally despite clearing document print commands and unplugging and resetting, dip switches may be defective or on-board software is corrupted.
Apr 18, 2009 | Epson Stylus Color 670 InkJet Printer
I have T6218 printer and it prints for about TWO minutes then starts slowing down and then stops printing showing an error of "HAMMER VOLTAGE 2". I relaced the Hammer coil kit in Banks 1 and 2. still same...
If you haven't fixed? If you don't get Hammer Voltage 2 error immediately, then sounds like your blower underneath the ribbon deck which keeps the hammerbank kewl is not working... Be careful but you can get shelf or cart about printer height and remove the ribbon deck with ribbon & cables still connected from the print. Rotate and sit it on the shelf or a cart. Start printing and see if the black blower(in the middle with a little black air duct going to the hammerbank) is working.
One other thing their's qty 7 hammer coils per hammer bank, if you have replaced the 1st 2 reading from left to right with hammerbank installed in printer, then you have qty 5 more which 1 of the 5 left is causing Hammer Voltage 2.
Have any other ??? feel free to call at x311
Toby
Feb 02, 2009 | Tally T6218 Matrix Printer
HUMMER VOLTAGE ERROR
There are two different Hammer Voltage errors on the 6306; Hammer Voltage 1 and Hammer Voltage 2.
Hammer Voltage 1:
One of the hammer drive circuits was turned on when it shouldn’t have been, so all printing has been disabled. The usual cause is a failed drive transistor.
Solution: Replace the Controller Board.
Hammer Voltage 2:
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Solution:
Check the hammer bank for defective coils.
May 07, 2008 | TallyGenicom 6306 Matrix Printer
Hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Tally 6306 Matrix Printer Logo
43 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
