Question about Oracle Computers & Internet
Error 1102 in oracle - Oracle Computers & Internet
What does it mean when I receive error code 1102?
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
Aug 01, 2014 | Kyocera Office Equipment & Supplies
I loaded a new colour cartridge in a lexmark p4350 it gives me a code 1102 i have cleaned the heads and still it gives an error 1102
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO). Please refer to this article to determine and resolve the issue: 1102 Error Message on the Lexmark P4300 Series All-In-One.
Apr 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
Code error 1102
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
Jun 07, 2010 | Kyocera FS-1118MFP Laser Printer
Orcale problem ?
This is an Error generated by the Oracle Client when the Oracle Server can not be reached.
This error can be caused by several items:
The Listener on the Oracle Server is not running. Check with an Oracle Administrator
The Oracle Server is off line. Check with an Oracle Administrator
The network connection to the Oracle server is not fully up and running. Check all connection points between the Notes server and the Oracle Server
A firewall exists between the Notes Server and the Oracle Server, and is not configured to allow access to both the Oracle Server's IP address and Port
The ADDRESS Parameter in the TNSNAMES.ORA file is incorrect. Use TNSPING (or TNSPING80 on Oracle 8.0.x) to check the connection to the Oracle Server. Example of a successful connection:
D:\ORANT\BIN>tnsping80 oracle
TNS Ping Utility for 32-bit Windows: Version 8.0.5.0.0 - Production on 23-APR-99
10:24:39
Attempting to contact (ADDRESS=(PROTOCOL=TCP)(HOST=DBSERVER)(PORT=1521))
OK (50 msec)
If this is Not successful, check your Oracle Network Products Messages Manual to resolve the errors that TNSPING points out.
well i found this from one site .... hope u can read it and can solve your problem
Oct 14, 2009 | Computers & Internet
Strtdb80.exe
First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Servic es\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Regards,
Mar 27, 2009 | Microsoft Windows XP Professional SP2
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
Oracle 10g Error
You're using the wrong password.
Sep 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Computers & Internet Logo
Top Oracle Computers & Internet Experts
CNewton2
CNewton2
Level 1 Expert
cwradio73
JonSnell Electronic
JonSnell Electronic
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
