Question about Frigidaire ATF6000ES Front Load Washer
Dropping the bottom front panel?
Sorry to be really ignorant but could you tell me how to drop the front pane to get to the clog i need to remove?
    Problem Solver:
  • 4 Answers
Judy,
There should be two screws at the very bottom of the machine on the front. You may have to tilt the machine back so you can see them. They are hard to see unless you get on the floor.
Also, I am curious as to what 'the clog' is that you are trying to get at. Are you trying to get to the drain pump and clear it out?
Posted on Nov 20, 2007
Clogging on filter. Dust not dropping into the holding tank
two things possible 1 oil on the filter 2 moisture so remove the filter wash with soapy(mild) water and dry really well wait for some one hour then use
comment after
Sep 12, 2015 | Filter Vacuums
Whirlpool lg5771xww0
You don't. You can access the valves easily by dropping the base panel. You should however take the front panel off and remove the drum if you wish to do the job right. Yank out the filter. Remove the 2 screws holding the top to the filter chute. Grab the back of the dryer and raise up on the top in front to release it. The unplug the switch which goes to the door and remove some screws to get the panel off. Take 2 springs loose from bottom before removing the panel screws. Get the drum out and clean her up. This is important. To swap out the coils you will need a phillps head driver take 2 screws out lift coils up unplug coils and attach the new ones. Ain't no way to screw up the repair both coils are different and only go in one way. Here is my video:
Jun 17, 2013 | Whirlpool Dryers
Procedure for replacing fuel pump for 1996 buick riviera
i am pretty sure this car has an inspection cover in trunk to gain access to pump assembly without dropping tank
Aug 16, 2011 | 1996 Buick Riviera
Will not come on electrolux cannister renissance
The Renaissance and a few other models require a series of steps in troubleshooting, done in specific order, to diagnose the problem. The vacuum, hose, wands, and power nozzle need to be taken to an authorized Aerus Electrolux shop for this. The service manual is only available to the service techs, and franchise owner.
If these steps aren't followed, additional problems may result.
Things you can check include:
1. Afterfilter. This is located beneath the on-board tools. Open the access door to the tool holder by pressing latch at front of door. Squeeze clips at the front of the tray and lift to remove. If the filter is dirty, replace it. Turn vacuum on and see if it works.
2. Check for clogs in hose, wands, and power nozzle.
Disconnect hose, hold one end up, and drop a coin in. Lift end of hose so that the coin drops out. If it doesn't there's a clog that needs cleared. You may be able to do this by attaching the hose to the blower hole, placing the other end into intake and holding it there, and turning on the vacuum. If this doesn't work, it will need to be taken to the Aerus shop for clearing.
Visually check wands for a clog. A clog in the wands can be cleared with a broom stick or similar item.
Visually check the power nozzle from the bottom and the wand connection. If no clog is seen, try dropping a coin into the wand connection and seeing if it drops through. A clog here can be cleared using a wooden spoon handle or similar blunt stick.
Feb 15, 2011 | Electrolux Lux 5500 Canister Vacuum
Clogged up
If there is no filter to be found at the front lower right of washer, then you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and checkjfor obstruction here and in the pump itself.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint WMM65 Front Load Washer
2004 expedition when a turn on the AC the vents in the front don't blow any air
sounds like the front blower motor is bad on the passenger side under the dash. remove the panel under dash and you will see the blower motor housing and blower motor. check the plug in on the bottom of motor if it is plugged up and not working pull the motor out by removing the screws around motor and dropping out hook directly to battery and see if it works if it does it is a fuse or relay.
Aug 31, 2009 | 2004 Ford Expedition
Need help with dryer repair.
open door top of door under lid remove screws lift lid more screws on sides that hold front panel on remove also lift front panel off...go to back remove 2 panels bottom one off undo belt panel 1/2 way up remove the re move e clip and washers now you can pull drum out the front watch wires on front pane..l wink.. smile... and 2 thumbs up i hope you have it unplugged hi hi
Aug 11, 2009 | Dryers
Getting an error code E20.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Voice is dropping last word
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel. * Use caution removing and reinstalling the front panel... it's somewhat fragile.
If this does not help, you need to try to run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jul 14, 2008 | Garmin StreetPilot c340 GPS Receiver
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
