Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer will not spin.
Two year old washer. Other phases of cycle seem ok ie. filling, agitating and draining. Prior to not spinning at all washer would spin but would not drain completely. Clothes felt heavy with water requiring a second spin. When the spin came to a stop you can hear the sound of an object braking it's speed by plowing through water even though there is no water visible in the bottom of the basket. This noise of the basket dragging through water is noticable when tub is empty and rotated by hand indicating the tub is not draining completely. Basket rotates by had but with considerable effort. Could this be clutch assembly, drive block or drive coupler assembly, none or all of the above.
  • jdboncher Jun 18, 2009
    Ordering the coupler today so that I have it on hand when I take the washer apart which could be up to a week depending when I get the part. Can the agitator work, although maybe not at full force, and basket not spin and still be indicative of a failed coupler? Also is the incomplete draining during the spin cycle related to the spin problem or a separate issue?
  • jdboncher Jun 19, 2009
    Removed cabinet and motor to inspect motor coupler which is in near perfect condition. Tried turning transmission shaft in both directions; moves freely counterclockwise but turns with lots of resistance in the clockwise direction. Tried turning the basket by hand counterclockwise which was accomplished with lots of force. I observed that turning the basket this way did cause the coupler connected to the trans shaft to turn clockwise but I don't know if a .5 hp motor could overcome this much resistance. Looking at the clutch assembly I don't see anything obvious that could be wrong ie spring is intact and no bent metal or metal filings but I don't really know what to look for. I don't think the lid switch is the problem because when the washer was plugged in and on the spin cycle with the lid down there was the motor noise normally heard on spin but no vibration or spin action; lifting the lid killed the motor sound so the switch is obviously activating and deactivating the motor which leads me to believe whatever is the problem must be on the transmission side of the motor
  • 583 Answers
Its better to put you up on source page then giving you short possibilities here. i will give you direct link to the page where you will find all the data about this problem and possible remedies too: here is the link: http://www.repairclinic.com/0088_11_1.asp#Level1_2
click the link and get all the possible data on this problem.
thanks and please do accept and rate this solution positively.
Posted on Jun 20, 2009
  • 1,170 Answers
If you know how to get the cover off and jump the lid switch it can be easy. first see if the motor is running, if its not most of the time the blue wire coming out of the timer controls the spin cycle. get a meter set it to read ac and see if you have 120v coming out. if you dont its the timer. if the motor is running, you probably need a clutch. also before you get too far check the lid switch. even of it looks good sometimes they split and appear to work normal. easy fix.
If the spin setting is not working chances are that your lid switch is bad. The lid switch is a safety feature installed that makes it so that unless the lid is closed the machine won't go into spin. This keeps from allowing the spin to shoot water all over the place if the lid is up. It is an easy fix though and very cheap. There are two panels on the side of the control panel. If you pop those off with a flat head screw driver you will find a screw holding down that control panel on each side. Remove those and then lay the panel back. Next insert the flat head under the front of the machine where the crack is at about an inch from the top of the machine. Pop it up and you will see the lid switch there underneath there. Remove it and follow to where it connects in the panel and disconnect and then install the new one. It should work fine again for you. Let me know if you have any other questions.
Could be the lid switch or the motor coupler. Click HERE to get a laymans guide to fixing this washer. It is easy to fix if you know the secret which is removing the cabinet.
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
Posted on Jun 19, 2009
  • 495 Answers
Not sure if this is belt driven or direct drive but if belt driven check the belt. I direct drive check the coupling between the motor and trans. Will only have to remove motor to check. If direct drive and coupling looks ok then the trans is locked up.
Check also this:
Remove power to unit.Remove 2 spring clips holding pump to motor. No need to remove hoses. Set pump aside. 2 springs hold motor to trans. Could be screw holding spring clips on but these are just fo shipping. Remove the spring clips and the motor will slide off. Look at coupling. Good or bad? Turn trans by hand in both directions. If it will not turn it is locked up.Work Safe. Good Luck
If there is problem with drive coupler then
Here is a link to website which explains how to install a drive coupler. In addition, it explains how to remove the outside shell of your washing machine to gain access to the items you need to access..... http://www.affordableappliance.com/Tips/CouplerInstallation.htm
Posted on Jun 18, 2009
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
