Question about HP 4440s Probook
Shuting down very slow - HP 4440s Probook
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
To check for performance issues
  1. Open Performance Information and Tools by clicking the Start button shuting down very slow - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type Performance Information and Tools, and then, in the list of results, click Performance Information and Tools.
  2. In the left pane, click Advanced tools.
  3. In Advanced Tools, under Performance issues, click any issues that are listed.
  4. Read the information in the dialog box that appears to learn which programs or drivers are causing problems.
If a program or driver prevents your computer from turning off quickly You can try the following tasks to fix the problem:
  • Close the program before shutting down. It's possible that the problem occurs only if the program is running. Try closing the program before shutting down Windows, and then see if your computer turns off properly.
  • Check with the manufacturer of the program or driver for an update. A newer version of the program might include a resolution to the problem.
If these options don't solve the problem, then the program or driver might be incompatible with Windows. If you installed the program or device yourself and you no longer use it, consider removing the device, or uninstalling the program or driver.
Posted on Apr 15, 2014
Shuting down when logged on
Try running in safe mode and dissable any new software.
Dec 03, 2013 | ASUS Eee PC 901
My receiver keeps shuting down when i turn it on
Denon receiver has a common problem, keep shuting down after power button press, then red light blind. mostly, if none of amplifier output transistors blown, it must be IC7815 or IC7915 mulfunction, find it, replace it. then job down
Mar 16, 2011 | Denon AVR-1601 Receiver
Pc very slow and window was shuting down late
it is possible that you have a virus or rootkit on the system,
if you go to www.bleepingcomputer.com they have a application called COMBOFIX, this app will scan and remove items that are infected (if any) there they also have a how to guide to using Combofix
hope this helps
Feb 09, 2011 | Computers & Internet
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
KEEPS SHUTING DOWN AFTERYOU START IT
check the igniter, maybe it is not hot enough anymore. it needs to glow white not orange. if it is orange change it.
Oct 24, 2009 | General Electric DWSR463GGWW Gas Dryer
Shutdown popup slow in appearing
ok get Windows XP mananger or TuneUP utilities and adjust the speed of your shut down, if you have a bluetooth adapter try shuting it's radio off at shutdown time.
Jul 10, 2009 | Microsoft Windows XP Professional SP3 Full...
ECG Schiller AT1 shuting down in work
Most likely needs a new battery. Can be ordered from R&D batteries.
Apr 08, 2009 | Schiller Cardiovit At 1 Ecg Machine
Water dripping from water shute just above ice maker;
Yes the water valve is not sealing correctly and if left untreated can cause issues with freezing up the pipe work and causing water to run down the back of the machine. the poor seal could be caused by grit or limescale getting trapped . it is very easy to change for someone who is diy minded.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Windows XP stops at "shutting down"....
It seems to me that You need to uncheck the "delete paging file at shutdown". Deleting the paging file slows the shutdown of Your system considerably.
Jan 11, 2009 | Microsoft Windows XP Professional With...
HP 4440s Probook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
