Question about Health & Beauty
Where would I get a wig wag for a vigor scooter??
  • 1,263 Answers
Hi , do you have a picture of this scooter ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Apr 19, 2014
2 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: i have a silver leader
hi,
ok so 7 flashes is a speed pot related error, you need to make sure that the speed pot is in the central position , look under the stem and you should see a cross head , now that should be straight not at slight angle, without you touching the throttle lever , if you have a meter disconnect the pot and take a resistance reading, it should show about 2.5K - using the centre tap , if it is a 5K pot fitted , in fact for that controller it should be a 5K pot , please check the terminal connections on the controller, good fitting and clean.
Take leave feedback.
Regards GeWiz.
Posted on Feb 11, 2011
Switch on, Press Wig Wag, Click click No Motor
Hi Peter, as a matter of interest check the brush holders, i seen a hugh number of those scooter lose the carbon part of the brush holder on the motor, they should be sticking out slightly or inwards...
otherwise . the throttle pot or wig wag as it can be called.
does the lever seem loose ?
A controller fault and i can test it for free for you , you only pay for the return postage..
Normally a blue unit..
Regards
Rob
Nov 20, 2015 | Pride Victory 4 Wheel Scooter
Just beeps when wig wag pulled but wont move
It could be the Wig-Wag needs replacing. But are there any fault bleeps or flashing lights. If so count how many and check in the trouble shooting guide of your user manual to tell you what the fault is.
Mar 24, 2015 | Health & Beauty
Why is my Invacare leo mobility scooter stopping and starting
It could be the wig-wag at fault and need replacing. A loose or bad connection on batteries or drive system. Speed pot worn.
Are the batteries old? May need load testing.
Mar 07, 2015 | Invacare Leo 4 Wheel Mobility Scooter...
Why when mobility scooter not moving when engaged but when disengaged moving slightly
The unit is not made for "medical approved" market and does not have a POST (Power On Self Test) to confirm wig-wag (throttle) is in neutral when it first turns on. SOLUTION: Put the scooter up on blocks so the drive wheels are off the ground. With the SPEED KNOB turned fully clockwise, adjust the wig-wag (throttle) so the cart will not run and the brake is engaged when the cart is in neutral. There are usually Allen screws in the wig-wag handle that can be loosened and re-tightened once the wig-wag pot is properly centered for neutral.
Aug 09, 2014 | Electric Strider Maxi 4 Wheel Mobility...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
Amigo problem
I had this problem similarly on an older trike I owned and still do.
If it stutters as it goes forwards, there is probably an intermittent connection between the wig-wag (the part you push to make the scooter go) and the rest of the electronics. It could be as simple as a loose wire or the whole wig-wag might need replacing. I'd recommend you take the scooter to your local dealer and have them reproduce the exact problem you're having and hopefully they'll be able to recommend a fix.
Apr 22, 2014 | Electric Strider Mini 4 Wheel Mobility...
Where will i get a replacement wig-wag for my Vigor mobility scooter. The old one is damaged.
You would probably have to contact a service tech for the product. This is usually a service call item unless the chair still works and the arm is just broken. You might be able to just get the arm. Some manufacturers require the whole assy to be replaced. That would require a tech unless you want to do the repair yourself. The manufacturer would not warrantee the part if you broke or damaged it while doing the repair yourself. They would for a certified tech.
Apr 15, 2014 | Ctm HS 890 4 Wheel Heavy Duty Power...
Electrics wont work
Please be more specific. Any flash or beep codes? Make\Model\Year of scooter? Is wig-wag pot {potentiometer} within tolerance? [5,000 ohms +/- 5%]
Mar 13, 2014 | Health & Beauty
Is it possible to reverse the drive lever on the invacare lynx scooter as my dad only has use of left arm. At the moment he has to push lever towards him very awkwardly. It would be much easier to simply...
Hi Mark.
Reversing the polarity:There are 3 wires on the Wig Wag Assembly. (reverse the wig-wag function) simply de-solder the 2 outer wires & swap their position & re-solder.I would seek a price for doing the job from an approved scooter repairer,unless you are comfortable doing the job yourself.I hope this has helped,Colin
May 07, 2012 | Invacare Supply Group Health & Beauty
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
