Question about Facebook Computers & Internet
They block me again
I know what do anymore
My email adress was blocked. How do i unblock it
What do you mean your email address was blocked?
What happened to make you think it is blocked?
If you were to send me an email and I decided I didn't want to hear from you anymore, I could block your email address but that would work just for me. Everyone else would still get your emails unless they specifically block you. I think there is some confusion as to what is actually happening but there is not enough data to know what.
Feb 16, 2017 | Computers & Internet
Expant Shield does not connect anymore. One day it worked fine and since about a week it does not connect anymore. No changes to location, computer, internet connection, etc. Possible that my ISP (I live...
That is a typical problem/issue. What happens is the ip block gets blacklisted and no longer works. All you need to do is wait a few days and it should work again. I think the longest I've seen it down lately is about 4 days or so. Hotspot is pretty proactive on fixing the connections so it usually is much faster. There are a few things you can try such as disconnecting, wait a minute and then reconnect to get a different ip. If the ip is out of the blacklisted range you should be able to watch the BBC/IT4 etc again right away. If not then about all you can do is wait and keep trying to connect. The disconnects I've seen recently are very short compared to when they first started. Those lasted weeks sometimes.
Oct 15, 2011 | AnchorFree Expat Shield
I've been blocked from flurv how can I use it again?
Unfortunately, if you have been blocked from a website, you are not allowed to use it or its features anymore. Unless you were IP banned, than you can make a new account and use that, than it should work. Hope this helped!
Sep 05, 2011 | Skout Flurv FlirtingA Singles Facebook for...
My friend cant call my house anymore because his number is blocked, how do i unblock his number so he can call the house again.
look in the front of your local phone book.. There should be some codes that will allow you to unblock the number.
Apr 16, 2010 | Lands Phones
Facebook wont let me play Farmville anymore.
Most likely you accidently blocked the Farmville application. To check if it's blocked, click your account settings in the upper right corner. Then go to Privacy Settings, and choose Applications and Websites. From there open the list of Blocked Applications. If Farmville is there, click remove and the block will be lifted and you will be farming once again.
Mar 28, 2010 | Facebook Social Network
Touch pad isn't working anymore.
Hi, to Enable the Pointer Device; go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this will fix it. paul7of9
Jan 14, 2010 | Acer Aspire One PC Notebook
My phone was blocked from my girlfriends and we cant unblock it??
No, the number is blocked by your girlfriends mom, and she'll have to unblock your number, or you can change your number....wallah unblocked!
May 02, 2009 | Lands Phones
I have an old Kenmore 26 side by side that dispenses water and ice. At one point it stopped producing ice and dispensing water. I changed the inline filter and it worked perfectly. Happened again shortly...
It sounds like you need to replace your water inlet valve , it is a dual valve for ice and water in the door and they go out often , the solenoid is not opening anymore , it is located where you hook up the water line.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Whirlpool GD2SHGX Refrigerator
Computers & Internet Logo
11 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
