Dux412 won't allow adobe reader to open quickly
My client had a dlink router - we upgraded to the duxbury 412. Since we put in the new router - when the users in the company go to open Acrobat reader - it is so slow to open. if we go back to the old router - Adobe reader opens fine. Any suggestions? We have uninstalled & reinstalled adobe. we have gone back to an older adobe reader. we have disabled protective view and 3d graphics in adobe. NONE of these things help. if I disconnect from the dux412 adobe reader opens fine. if I attach the old router, adobe reader opens fine. as soon as we put in the dux412 adobe reader takes soo long to open. It is happening on all machines in the office - so it is not specific to the machine configuration. Any help would be appreciated - am pulling out my hair!!! regards Susan
sandrew
  • 2961 Answers
SOURCE: compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
Posted on May 17, 2007
  • 883 Answers
SOURCE: adobe acrobat reader is not opening...
if you have the original install disk for adobe acrobat reader the uninstall the program then power down then re-install the program
Posted on May 23, 2007
Kawika-56
  • 233 Answers
SOURCE: Adobe Acrobat 8 does not integrate with MS Office 2007 programs
Then do a search for 'all files and folders' - search for both Acrobat 6.0 and then Acrobat 7.0, with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those related files found.
You should do this search and delete whenever you uninstall any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling.
Posted on Dec 06, 2007
muscularmod
  • 66 Answers
SOURCE: dlink wireless router (DL-634M) and windows XP
have you configured the routers firewall using the given ip address, you have to type it in internet explorers browser window
Posted on Dec 12, 2007
SOURCE: Adobe Acrobat 8 error 2711
Sounds menacing but it’s fairly easy to fix.
Heres how to fix it:
  1. Download msicuu2.exe (Windows Install Cleanup Utility) from Microsoft, or by clicking on the file name.
  2. Run msicuu2.exe
  3. You will then get a message asking if you wish to roll back the in progress installation. You do.
  4. Install Adobe Acrobat or Reader 8.
Adobe’s more intrusive way of fixing it:
  1. Click Start>Run, type in regedit then hit enter or press ok.
  2. Back up your registry (not actually mentioned by adobe but a good idea whenever you’re about to make changes to the registry)
  3. Look for Key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Inprogress
    and delete the key if it exists.
Posted on Sep 10, 2008
How I put a password
How to recover my login Facebook password
Mar 09, 2015 | D-Link DIR-412 Mobile Broadband Wireless...
Plug the old router in and check the configuration. There may be either a port opened to allow Adobe to update or possibly a port trigger.
If it is set to check for updates on startup and it cannot get out to verify, it can slow it down.
Apr 15, 2014 | Computers & Internet
Connecting wireless router to server
If routing and remote access is enabled on the server, it should handle the bridging automatically between the two nics...
Otherwise, simply turn off the DHCP in the router, have the server and all the clients connect to the LAN ports, and they will automatically get their address from the server. In this scenario, you don't need to worry about the WAN port on the router.
But you might want to think about using the WAN port on the router to provide an added layer of security rather than exposing your server directly to the internet. You can set up all the port forwarding you need on the router.
More info here:
http://www.dlink.com/us/en/support/product/dwl-g700ap-high-speed-2-4ghz-802-11g-wireless-access-point
The manual is here:
http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DWL/DWL%20G700AP/Manual/DWL_G700AP_Manual_EN_US.pdf
You need a pdf reader (adobe) to read the content.
Good luck.
Nov 18, 2012 | D-Link DWL-G700AP 802.11g/b Wireless...
Have just brought a dlink dir-412 and am trying to connect to sierra wireless aircard 312u through telstra. when trying to install through dlink comes up with no xml data. Have no idea how to fix, also is...
1. check the firewall setting in Windows
2. check the firewall setting in the router and the wireless allowances in the wireless list for device ( located in the wireless router
3. you must allow a wireless device to access the router.
the data from the web for the device is not reaching the pc to display the pages
this is by permissions in the router and the firewall
4. check your anti virus settings also.
Aug 12, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
I want to put a password on my internet connection to secure from other to use.i use dlink dir 412 as router.
Thank you for using FixYa
Push the WPS button.
I hope this was useful and please comment if this was helpful to you.
Mar 14, 2011 | Computers & Internet
I forgot my passkey
You are supposed to set that yourself. Read your manual (they have electronic manuals on the dlink website). type "192.168.0.1" into your web browser and you can configure your router from there. Just click the wizard button and it will guide you through everything.
There should be a reset button on the back of the router that you press with a paper clip for 10 seconds, and that resets everything to factory default settings.
Dec 24, 2007 | D-Link 802.11g Wireless Router WBR-1310...
DI-524 Configuration as "Client"
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
David Payne
David Payne
