Question about Water Heaters
Bosch ecologixx 7 manual - Water Heaters
My pieps froze and now my tankless water tank leaks how do i get a new part
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Mar 27, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
My Bosch Water Heater keeps going off. I reset it and then A7 keeps coming up. We had a power outage for about 6 days. I do not have the manual. Do you know what it is and how to fix it? Thank...
Questions might be asking for a manual, and asks what error A7 means, and asks how to fix error problem, but model number of Bosch heater is not given.
Error codes are start-point for troubleshooting, and can include multiple causes.
So following answer provides general do-it-yourself resources, without saying that problem can be 100% diagnosed or fixed by homeowner.
1) Error code A7 is outlet temperature sensor fault.
Problems include: need for descaling, dirty inlet water filter, debris in faucet aerators, dirty wiring terminals, bad wiring harness, or bad temperature sensor.
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
2) Before calling service technician who can test failed parts and catch tankless up on yearly maintenance, open following links for Bosch resources including error codes, phone number, possible manual, and descaling instructions, and cleaning inlet filter:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-12_Cleaning_inlet_filter.pdf
3) Product manual: Question posted under model 125HX-LP
Open following link for possible manual:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/InstallationManuals/tabid/542/Default.aspx
4) Do it yourself service bullitens for 125HX-LP
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/ServiceBulletins/tabid/548/Default.aspx
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Bosch AquaStar Propane Tankless Water...
We have to reset daily A-7
Before calling service technician, open following link for troubleshooting resources including error codes, manual, links to bosch, phone number, :
Temperature below freezing or above 210 degrees F
1) Check red wire connections at hot water temperature sensor. Clean terminals with an eraser. If badly corroded, replace sensor and wire harness. (See Fig. 63, page 46 in manual).
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions. Any damage due to freezing conditions is not covered under warranty.
3) Clean inlet filter screen and clear any debris out of shower heads, faucet aerators and whole house filters.
4) In areas where water has a high mineral content, periodic descaling may be necessary.
Apr 17, 2011 | Bosch AquaStar 2400ES-NG
Hi, I have a Bosch tf 400 ng 1tr, about 7 years old, just today it started producing only 1/2 the heat. Any suggestions ( I have gas experience on cookers and stoves) so I should be able to fix if I'm...
You ask for free nudge:
I have links for resourceful do-it-yourselfer since tankless is large and developing field that can take years of study.
For example tankless are prone to lime build-up and must be de-limed each year. Search utube for 'delime tankless' to help restore efficiency.
Best place to start is troubleshoot section in your product manual.
1) BOSCH website is easy to navigate:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
2) Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
3) Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
4) Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
5) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/pro-n-con.html
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 14, 2011 | Bosch Water Heaters
Will not stay lit.
You posted under Bosch tankless water heater.
Fixya is ready to assist resourceful do-it-yourselfer, so read information below, and if you are unable to determine what problem is, post another question saying what you've done so far, or contact service technician and when technician arrives, ask that person tricks and tips for maintaining your tankless water heater.
1) Best place to start is troubleshoot section of manual.
Bosch manuals:
2) Open pdf of typical manual: troubleshoot section page 33.
http://www.boschhotwater.com/Portals/7/TechManuals/2400E_English_12_2007.pdf
http://www.boschhotwater.com/Portals/7/TechManuals/250SX_English.pdf
3) BOSCH error codes
5) Bosch problems at Fixya:
6) Read manual cover to cover
and make sure maintenance is scheduled.
For example de-liming is recommended each year.
Utube search de-lime tankless water heater
7) Install DIY tank-type gas water heater and avoid the whole headache
Mar 10, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Have Error code FO, no hot water. Press reset and water gets warm for few seconds then goes off again.
1) BOSCH website shows error codes.
FO does not appear:
2) I do not see FO error code listed on Internet search
Other FO questions at fixya seem to have no answer:
http://www.fixya.com/tags/error_f0_bosch
3) At this point, I would suggest calling a service technician.
While waiting for service, read manual cover to cover several times.
4) Your manual is valuable resource, and shows the word 'maintenance' and 'troubleshoot' frequently.
Tankless are maintenance heavy, and should be de-limed each year.
U-tube search "delime tankless water heater."
5) Also explore Bosch website for your manual and other valuable information.
6) When service tech arrives, ask that person for tips and tricks about your unit that will help you maintain your water heater.
7) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache.
Mar 08, 2011 | Bosch Water Heaters
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
BOSCH error codes:
Mar 05, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 250 sx ng tankless water heater showing error code. checked fuses and they are fine. tried resetting many times still not working
BOSCH error codes:
Best place to start is troubleshoot section in manual. Page 24
Problems range from air supply, gas supply, venting, part failure or combination of listed things.
Don't forget, tankless require yearly maintenance, outlined in manual, and cannot be exposed to more than 11 grains hardness in water, and should be de-limed each year.
I suggest reading entire manual several times, so you are pro about your tankless water heater.
Even with this knowledge, trained service technician will have to be consulted
some day, and tankless should never be installed if factory trained technician not available in area.
Install tank type water heater that can be put online when Bosch is not working
Mar 04, 2011 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
