Dux412 won't allow adobe reader to open quickly
My client had a dlink router - we upgraded to the duxbury 412. Since we put in the new router - when the users in the company go to open Acrobat reader - it is so slow to open. if we go back to the old router - Adobe reader opens fine. Any suggestions? We have uninstalled & reinstalled adobe. we have gone back to an older adobe reader. we have disabled protective view and 3d graphics in adobe. NONE of these things help. if I disconnect from the dux412 adobe reader opens fine. if I attach the old router, adobe reader opens fine. as soon as we put in the dux412 adobe reader takes soo long to open. It is happening on all machines in the office - so it is not specific to the machine configuration. Any help would be appreciated - am pulling out my hair!!! regards Susan
    Problem Solver:
  • 12 Answers
Plug the old router in and check the configuration. There may be either a port opened to allow Adobe to update or possibly a port trigger.
If it is set to check for updates on startup and it cannot get out to verify, it can slow it down.
Posted on Apr 23, 2014
SOURCE: Configuring DLink Wifi router for Reliance broadband
Reliance Wimax will be Dynamic (DHCP)
Step 1 :
Connect the Wimax wire from the wall outlet (power adapter provided by Reliance) to the computer directly. The computer must be in DHCP mode.
Check the IP Address of the Computer. It should be a public IP Address.
Step 2 :
Open a web browser. If you try to open any page, it will take you directly to the Reliance Broadnet Login page. Login with your Reliance User ID and Password. Then Log out.
Close the web browser.
Step 3 :
Now, connect the wimax wire to the WAN Port on the Router and the computer to any LAN port. You can open the Router Setup Page. Do MAC Cloning. Then, save changes. Run DHCP on the Router.
Also you can configure wireless network, by changing the SSID and security.
Step 4 :
On the wired computer, open web browser, go to Reliance Broadnet login page and login and start enjoying the service.
One problem, you might face is when the Router is turned off in between. You may have to repeat the Steps 1,2 & 3 to get the connection back.
Posted on Oct 20, 2008
muscularmod
  • 66 Answers
SOURCE: dlink wireless router (DL-634M) and windows XP
have you configured the routers firewall using the given ip address, you have to type it in internet explorers browser window
Posted on Dec 12, 2007
sandrew
  • 2961 Answers
SOURCE: compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
Posted on May 17, 2007
beeveez
  • 167 Answers
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Posted on Mar 08, 2009
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Posted on Mar 17, 2009
How I put a password
How to recover my login Facebook password
Mar 09, 2015 | D-Link DIR-412 Mobile Broadband Wireless...
Connecting wireless router to server
If routing and remote access is enabled on the server, it should handle the bridging automatically between the two nics...
Otherwise, simply turn off the DHCP in the router, have the server and all the clients connect to the LAN ports, and they will automatically get their address from the server. In this scenario, you don't need to worry about the WAN port on the router.
But you might want to think about using the WAN port on the router to provide an added layer of security rather than exposing your server directly to the internet. You can set up all the port forwarding you need on the router.
More info here:
http://www.dlink.com/us/en/support/product/dwl-g700ap-high-speed-2-4ghz-802-11g-wireless-access-point
The manual is here:
http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DWL/DWL%20G700AP/Manual/DWL_G700AP_Manual_EN_US.pdf
You need a pdf reader (adobe) to read the content.
Good luck.
Nov 18, 2012 | D-Link DWL-G700AP 802.11g/b Wireless...
Have just brought a dlink dir-412 and am trying to connect to sierra wireless aircard 312u through telstra. when trying to install through dlink comes up with no xml data. Have no idea how to fix, also is...
1. check the firewall setting in Windows
2. check the firewall setting in the router and the wireless allowances in the wireless list for device ( located in the wireless router
3. you must allow a wireless device to access the router.
the data from the web for the device is not reaching the pc to display the pages
this is by permissions in the router and the firewall
4. check your anti virus settings also.
Aug 12, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
I want to put a password on my internet connection to secure from other to use.i use dlink dir 412 as router.
Thank you for using FixYa
Push the WPS button.
I hope this was useful and please comment if this was helpful to you.
Mar 14, 2011 | Computers & Internet
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
I forgot my passkey
You are supposed to set that yourself. Read your manual (they have electronic manuals on the dlink website). type "192.168.0.1" into your web browser and you can configure your router from there. Just click the wizard button and it will guide you through everything.
There should be a reset button on the back of the router that you press with a paper clip for 10 seconds, and that resets everything to factory default settings.
Dec 24, 2007 | D-Link 802.11g Wireless Router WBR-1310...
DI-524 Configuration as "Client"
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
