SOURCE: seagate HDD external drive
set its jumpher ot the slave position and plug it on ide2/secondary port of the motherboard and dected it from bios setting of the pc which appears when u press delet/f2 buttin when computer starts.
SOURCE: i have a problem .i.e
Its a master/slave problem. Put it to cable select mode
http://www-307.ibm.com/pc/support/site.wss/42470_hdd4.gif
Put the jumper to CS then reboot.
SOURCE: st3160827as seagate hdd is
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
