Question about Brother HL-2040 Laser Printer
Go light flashes no print
Tried to push 3 times go button but no set up page
    New Friend:
  • 78 Answers
Try holding go button until light flashes and release.
Posted on Apr 26, 2014
5 Suggested Answers
Srid
  • 10 Answers
SOURCE: after changing cartridge, printer won't print a full page, gets stuck and all lights are flashing
Some problem in Catridges, take the white petrol and clean the head of the catridge and try again.
Posted on Sep 29, 2007
maverick24
  • 56 Answers
SOURCE: Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Posted on Dec 05, 2007
SOURCE: I have the drum, alarm and data light on. will not print.
All fixed now I put another toner cartridge in it
Posted on Nov 12, 2008
Just4help
  • 145 Answers
SOURCE: Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
Posted on May 26, 2009
I just replaced my ink on E238 laser printer and the yellow light is flashing. I have been on hold for 45 mins with you help line. Everything still prints but the light is flashing
  1. Enter the printer's Configuration Menu. To do this:
  2. Turn off the printer.
  3. Open the front cover
  4. Press and hold the Continue () button.
  5. With the front cover open and the Continue button pressed down, power on the printer.
  6. Hold the Continue button until all the lights cycle.
  7. When just the Error light (!) is displayed, close the front cover. The top four lights of the operator panel should come on, indicating that the printer is in configuration mode.
  8. Print the Configuration Settings page. To do this:
    • Press and hold the Continue () button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the nonĀ·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
      Save this page for possible later use.
  9. Reset the photoconductor page count as follows:
  10. Press and release the Cancel button () to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low () light is the only light left on.
  12. Press and hold the Continue button until all of the lights flash.
  13. Then release the button. When the Toner Low light is once again the only light left on, the photoconductor page count should be reset to zero.
  14. Return the printer to normal mode. To do this:
    • Power it off for five seconds and then turn it back on.
  15. Print a menu settings page. To do this:
    • When the Ready () light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
  16. Check the photoconductor reading on the menu settings page. To do this:
  17. Look for a section labeled Cartridge Information and locate the word Photoconductor under that heading.
  18. Confirm that the photoconductor level reading is OK or close to 100%.
  19. If the photoconductor reading is low, try printing 10 - 20 pages.
  20. Print the menu settings page(s) again. Confirm that the photoconductor level reading is OK or close to 100%.
  21. If the photoconductor reading is still low, refer to the Configuration Settings page you printed in Step 2.
  22. Confirm that Reset Photoconductor Counter is listed on the page.
    Also confirm that the light sequence for the photoconductor counter is the Toner Low light.
    • If the light sequence is correct, try repeating this entire procedure again from the beginning to reset the counter once more.
    • If a different light sequence is listed for the photoconductor counter, repeat the procedure but this time, instead of stopping at the Toner Low light (Step 3.2), press the Cancel button until the operator panel shows the light sequence that corresponds to the one listed on the Configuration Settings page. Continue with the remainder of the procedure as before to reset the counter again.
  23. If the photoconductor reading is still low after the page reset procedure has been performed twice, the printer may require service.
May 04, 2011 | Lexmark E238 Laser Printer
How do I program my clock on my 2001 Yamaha Roadstar 1600?
View the service manual at this URL : http://www.scribd.com/doc/17625151/servicemanual1602082008 : and scroll down to printed page 3-62 or electronic page 120.
Copying from that page:
1. Turn the main [ignition] switch to "ON".
2. Press both left and right buttons simultaneously [i.e., the 2 buttons below the speedometer glass] until both hours and minutes flash
3. Push the left [mode] button and the hour display will flash
4. Push the right [right] button to change the hours.
5. Push the left button and the minute display will flash.
6. Push the right button to change the minutes.
7. Push the left button and both hours and minutes will flash.
8. Push the right button for two seconds to set the clock.
Sep 01, 2010 | 2002 Yamaha Road Star
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
Printed pages come out blank
Hello please try this
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Jun 01, 2009 | Canon BubbleJet i550 InkJet Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
Dell Printer 1720dn - Unable to reset drum counter..
"Press & hold the cancel button untill all lights start flashing in a sequence and then i release the button and close the front cover." "DO NOT release the button, but continue to hold down it while you close the front cover.
Printer offline: Right click on your printer in the "Printers and Faxes" folder and "UN Check" use printer off line,
May 11, 2009 | Dell 1720dn Laser Printer
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Nov 22, 2007 | HP Photosmart 7850 InkJet Printer
After changing cartridge, printer won't print a full page, gets stuck and all lights are flashing
Sep 28, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
