Question about Sony Playstation 3 (PS3) Console
Ps3 starts freezing after pressing the ps button
Well my ps3 is about 2 years old and i had never had problems with my system . until it started freezing everytime i pressed the ps button what is the problem ?
    President:
  • 2,653 Answers
Corrupted data on the hard drive.
back up any important files and run the restore to factory settings option.
That will clear the problem.
Posted on Jun 19, 2009
When playing ps3 it keeps freezing
Hard Drive
If your PS3 lags or freezes when loading content from the hard drive, the drive either lacks free space or is faulty. To create more space, try removing items from your hard drive or getting a new hard drive with a higher storage capacity. A faulty hard drive must be replaced.
PlayStation 3 Troubleshooting
Apr 21, 2014 | Sony Playstation 3 (PS3) Console
Wen i want to play a game on line that i have is ascking to do the update, the update starts then stops freezing what should i do
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Regards.
Jan 11, 2012 | Sony Playstation 3 (PS3) Console
My ps3 freezes upon start up, or shortly after. sometimes it freezes when trying to get into safe mode. sometimes i just get a black screen and my controllers won't connect. everything worked fine on...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Aug 15, 2011 | Sony PlayStation® 3 (60 GB) Console
Ps3 freezes.XMBshows the top row of icons but nothing below them except onthe settings column and when you go down that column and click on something the whole thing freezes
Follow the procedure below to fix the problem on your ps3,
• System Update: Update the PLAYSTATION®3 System.
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
The screen get freeze with multi colors dots on it
Take care.
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
Hi my playstation keeps freezing and everytime i follow the instructions on the playstation it freezes again. it now wont start correctly. Could you help me please ?
Hello
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down. If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on. Check if there's any loose cables. If there is, put them back in.
If the problem still persist, try the below steps,
Take care.
Jul 09, 2010 | Sony Playstation 3 (PS3) Console
Ps 3 freezes when ps button is pressed
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
Freezing and not reading
Sounds like your System has become corrupted.
Have you already tried the System Restore function?
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezes before getting to main menu!!
I had the same problem bud. I rushed and contacted sony but the next day my friend told me a great solution tht safed me 150 $. Well basicly your ps3 is lika a PC. All you nerd to do is to get to the hard drive menu. By holding the power button for 10 sec but do that for 3 times. That will take you to the blue menu. From there just reset your hard drive and wola brand new.
Ps Same thing happend after i downloaded the house app. booo to the house lol
Jan 20, 2009 | Sony PlayStation® 3 (60 GB) Console
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
327 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
