Teac ref 500 cd player does not play disc.
Message on display" no disc"
    Champion:
    Habit-Forming:
  • 239 Answers
Worn or dirty laser
Posted on Aug 09, 2014
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
SOURCE: c-314 stanton cd player, reads no disc, but disc is in cd player
as with my other posting - all i could do was mail it to be fixed. then it stopped working again so perhaps its time to go elsewhere.
Posted on Oct 13, 2008
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
  • 65 Answers
SOURCE: Teac CR H100 CD player just clicks when I press
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Posted on Sep 23, 2010
Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Teac GF-350 CD Shelf System
Display Panel
The problem is not with the display panel, it is with the changer mechanism. It may cycle through all five disc positions without playing a single one
Dec 03, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
Price of it
Hello
The device you speifies here have a cost of 500 British Pounds.
For more details get into this website
www.stocktogo.co.uk/teac-pdh303-changer-hifi-separate-gold-p-1664.html - Cached
OK.
May 15, 2011 | Teac PD-H303 3-Disc CD Changer
Read error
Some recorders, especially Phillips REQUIRE using the "Music" CD's. It was a lame attempt at copyrright enforcement.
Dec 15, 2009 | Teac CD-RW880 CD Player / Recorder
Mar 14, 2009 | Teac PD-H300 CD Player
Jun 18, 2008 | Teac CD-P1250 CD Player
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
PL-D2000 DVD Home theater System
Comments: To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region Ensure TV monitor is on so and set to display DVD. 1. Turn system completely off. 2. Turn on system. 3. Open tray. 4. Using remote press and hold the return button. 5. While holding the RETURN button, press and hold the DISPLAY button. 6. You will see something like this displayed on screen: VER 1006 TE 3210 7. Release DISPLAY and RETURN buttons simultaneously. 8. Press the ANGLE button. You will see WRITING REGION ID displayed. You can now play DVDs from any region. 0
May 27, 2007 | Teac PLD2000 System
64 people viewed this question
 Grubhead
Grubhead
