Question about Garden
How do i clean the spark plug - Garden
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Do not clean it replace it their really is no proper way a new properly gapped will give you a better running engine the old one if it is worn will give you the same problem again.
Posted on Apr 15, 2014
Won't start,charged oil,cleaned spark plug and air filter.has gas.
If your tiller has sat for any length of time it may have stale gas and the spark plug may need replacing (not just cleaning). Always make sure all wiring and or connections are clean. You can check for spark by removing spark plug, insert it back into spark plug wiring, using a WOOD clothes pin to hold the wire, hold spark end of spark plug (holding the clothes pin only) on metal casing on machine, pull starter cord and check for spark. If you don't use a non conductive instrument such as the clothes pin you will get a nasty shock. If you have no spark it is time to change the plug. Always put your safety first! Hope this helps! Have a great day! If this doesn't work perhaps you will need more information.
Mar 30, 2015 | Troy-Bilt Pony Garden Tiller
Tip
How to Test Spark Plugs in Audi A6 car?
1) Test the spark plug ignition. For that disconnect the spark plug wire from the spark plug.
2) Then touch the spark plug wire close to a metal surface of the car. Then spin the key in ignition switch. If you will see a spark or hear a crackling noise. This means the wire to the spark plug has voltage in it.
3) If there is no spark when you crack the engine it means that a spark plug wire is dead.
4) Check out all the battery cable, ignition wires and coil wires are hooked up properly to their points.
5) If any of the battery cable, ignition wires and coil wires is loose then this can also relate to no spark.
6) But if all the battery cable, ignition wires and coil wires are properly connected then its time to replace the spark plugs.
7) Before replacing clean the old spark plugs connections and recheck.
8) Many a time’s cleaning or moving the spark plug connections makes it work.
9) If nothing is getting the spark plug to spark, then it needs replacement.
This will help. Thanks.
on Mar 15, 2010 | Audi A6 Cars & Trucks
How to change spark plugs
REMOVAL PROCEDURE
  1. Remove the ignition control modules.
  2. Clean the spark plug recess area with low pressure air.
CAUTION: Wear safety glasses when using compressed air, as flying dirt particles may cause eye injury.
NOTE: Clean the spark plug recess area before removing the spark plug. Failure to do so could result in engine damage because of dirt or foreign material entering the cylinder head, or by the contamination of the cylinder head threads. The contaminated threads may prevent the proper seating of the new plug. Use a thread chaser to clean the threads of any contamination.
117381099
  1. Remove the spark plugs from the cylinder heads.
NOTE: Allow the engine to cool before removing the spark plugs. Attempting to remove the spark plugs from a hot engine may cause the plug threads to seize, causing damage to cylinder head threads.
  1. Inspect the spark plugs. Refer to Spark Plug Inspection.
INSTALLATION PROCEDURE
  1. Measure the spark plug gap on the spark plugs to be installed. Compare the measurement to the gap specifications.
NOTE:
  • Use only the spark plugs specified for use in the vehicle. Do not install spark plugs that are either hotter or colder than those specified for the vehicle. Installing spark plugs of another type can severely damage the engine.
  • Check the gap of all new and reconditioned spark plugs before installation. The pre-set gaps may have changed during handling. Use a round feeler gage to ensure an accurate check. Installing the spark plugs with the wrong gap can cause poor engine performance and may even damage the engine.
117381099
  1. Install the spark plugs to the cylinder heads.
NOTE:
  • Be sure that the spark plug threads smoothly into the cylinder head and the spark plug is fully seated. Use a thread chaser, if necessary, to clean threads in the cylinder head. Cross-threading or failing to fully seat the spark plug can cause overheating of the plug, exhaust blow-by, or thread damage.
  • Refer to Component Fastener Tightening Notice in Service Precautions.
Tighten the spark plugs to 20 N.m (15 lb ft) .
  1. Install the ignition control modules.
Jul 14, 2014 | 2006 Cadillac SRX
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Clean spark plug 2 cycle engine
Hi chldrz...
Remove the spark plug, clean post and arm with a wire brush, and then use light sandpaper to clean and level the two firing surfaces...(the post and the arm)
Replace plug if it wors fine, if not replace the plug.
Please take time to rate me
Thanks,
Bud
Feb 20, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
I want to clean the spark plug
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Fouled Spark Plugs cleaning and testing
Spark Plug Cleaning
Old Mechanic Trick Clean Spark Plug
Top results matching Bajaj Discover service manual Scribd
Bajaj Discover 100M 2014 service manual DOWNLOAD FREE FULLMANUALS COM
Jan 15, 2013 | 2006 Bajaj Discover
How do you replace spark plugs on f150 4.6 2007
It can be faulty or dirty spark plug itself. Also for reference get the fuel level checked. Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helping. On some cases the black carbon layer gets collected on the spark plugs and that causes the problem, so cleaning the plugs help. But if its not helping, then spark plug has to be replaced. Spark plugs get power from ignition coil to ignite sparks. If ignition coils are faulty then also there will no spark. --------------
To troubleshot and confirm the issue, I suggest you to go through the help link provided below, check the procedure and it will help you to confirm the issue in your case.
Click the link below:----
http://alltypesofpartsreplacing.blogspot.com/2012/12/no-spark-faulty-spark-plugs-replace.html
These will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Where are the spark plugs located on the car
They are underneath the coils,there will be a coil,and under the coil will be a spark plug boot connecting the coil to the spark plug.
Oct 30, 2009 | 2001 Oldsmobile Intrigue
Where are the spark plugs on my 2000 Oldsmobile Intrigue and how do i change them?
2000 Oldsmobile Intrigue V6-214 3.5L VIN H SFI
Spark Plug: Service and Repair
REMOVAL PROCEDURE
TOOLS REQUIRED
J 43094 Spark Plug Boot Puller
1. Turn OFF the ignition switch.
2. Remove the ignition coil assembly.
3. Use the J 43094 in order to remove the spark plug boots from the spark plugs.
threads to seize causing damage to cylinder head threads.
4. Remove the spark plugs from the engine.
NOTE: Use only the spark plugs specified for use in the vehicle. Do not install spark plugs that are either hotter or colder than those specified for the
NOTE: Check the gap of all new and reconditioned spark plugs before installation. The pre-set gaps may have changed during handling. Use a round
engine.
1. Measure the spark plug gap on the spark plugs to be installed. Compare the measurement to the gap specifications. Refer to Spark Plug Usage.
Correct as necessary.
NOTE: Be sure that the spark plug threads smoothly into the cylinder head and the spark plug is fully seated. Use a thread chaser, if necessary,
thread damage.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the spark plugs to the engine.
Tighten
Tighten the spark plug to 20 N.m (15 lb ft).
3. Install the spark plug boots to the ignition coil assembly.
4. Install the ignition coil assembly.
Sep 13, 2009 | 2000 Oldsmobile Intrigue
How to replace sparl plugs on a Jeep Cherokee?
Hello, I hope this info helps...(subytech1)...REMOVAL
In this engine, each individual spark plug is located under each ignition coil.
  1. Prior to removing spark plug, spray compressed air around base ofignition coil at cylinder head. This will help prevent foreign materialfrom entering combustion chamber.
  2. On this engine each individual ignition coil must be removedto gain access to each spark plug. Refer to Ignition CoilRemoval/Installation.
  3. Check condition of coil O-ring and replace as necessary.
  1. Inspect spark plug condition. Refer to Spark Plug Conditions.
CLEANING
Theplugs may be cleaned using commercially available spark plug cleaningequipment. After cleaning, file center electrode flat with a smallpoint file or jewelers file before adjusting gap.
CAUTION: Never use a motorized wire wheel brush to clean sparkplugs. Metallic deposits will remain on spark plug insulator and willcause plug misfire.
ADJUSTMENT
Setting Spark Plug Gap - Typical
Check spark plug gap with a gap gauge tool. If the gap is not correct,adjust it by bending ground electrode. Never attempt to adjust gap bybending center electrode.
INSTALLATION
CAUTION: This engine is equipped with copper core groundelectrode spark plugs. They must be replaced with the same type/numberspark plug as the original. If another spark plug is substituted,pre-ignition will result.
Special care should be taken when installing spark plugs into cylinderhead spark plug wells. Be sure plugs do not drop into plug wells asground straps may be bent resulting in a change in plug gap, orelectrodes can be damaged.
Always tighten spark plugs to specified torque. Over tightening cancause distortion resulting in a change in spark plug gap or a crackedporcelain insulator.
  1. Start spark plug into cylinder head by hand to avoid cross threading.
  2. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  3. Before installing coil(s), check condition of coil O-ring andreplace as necessary. To aid in coil installation, apply silicone tocoil O-ring.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
Aug 07, 2009 | 2000 Jeep Grand Cherokee
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
