Question about Teac PD-H500 CD Player
No disc message in teac pdh500 cd player
"no disc" message on display
    Champion:
    Habit-Forming:
  • 239 Answers
Worn or dirty laser
Posted on Aug 09, 2014
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Posted on Jul 07, 2008
localwonder
  • 6784 Answers
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly.
Posted on May 29, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
My teac recorder model # cd-rw890 keeps flashing "reading" and will not let me operate the cd drive
How long have you had you CD recorder?
How many CDs have you burned on it?
The reason for asking is, it sounds like the laser has
failed or is failing to the point of not recognizing the
presence of a disc in the tray. Does it do this with any
disc you put in the tray. Blanks & pre recorded CDs?
A minimum amount of light must bounce back from the
surface of the disc or the unit thinks the tray is empty.
If the laser has become very weak (or died) the player
doen't know any better and thinks "no disc".
The "reading" message just indicates it hasn't passed
the stage where it has detected a disc, yet.
The first step is to run a laser cleaning disc in the player
on the off-chance the lens is dusty and that's the problem.
If you don't have one (you should) they're cheap enough
and available everywhere. If cleaning doesn't help, you
will be looking for a new laser assembly for your unit.
Be careful how much you pay for one. New 890s can be
had from Full Compass for under $200.00 and would be
a smarter move than repairing a tired one!
Oct 23, 2014 | Teac America, Inc Teac CD RW890 - CD...
Display Panel
The problem is not with the display panel, it is with the changer mechanism. It may cycle through all five disc positions without playing a single one
Dec 03, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
I have a Teac D250 CD recorder it used to use TDK XA80 CD-R discs these are off the market and no other disc seems to work . It displays D-Unclock when I try . Is there a code to unlock this so that I can...
You have to look for input selection and make sure whatever way your recording from is connected. If you doing digital to digital, make sure the optical line is connected and the other is powered on. if it's analog or input or other also the same. I think it needs to recognize the other device. This is info from my teac rw d200. I love this and also use these disc's and maybe they would work on yours. The CD's MUST be made for Audio Burners and I recommend these two kinds...The label below MUST be printed on the CD's in order to work.
8_31_2012_5_05_37_am.jpg8_31_2012_5_06_16_am.jpg8_31_2012_5_06_28_am.jpg8_31_2012_5_22_59_am.jpgthese RW and all purpose are whatever you can find online. The RW just became discontinued. I bought some 2 years ago.
Jun 10, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
May 29, 2009 | Teac CD-P1120 CD Player
CD player TEAC DC-D350 When inserting CD >>message 'disc' shows up. Suspect Laser diode faulty. Should the Laser be on only with CD inserted ? or anytime when player is 'ON'...?
It must probably be a laser faulty, however it could also be derived from something that you can solve by cleaning.. The laser should be on only with cd inserted.
Sep 03, 2008 | Teac Audio Players & Recorders
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
PL-D2000 DVD Home theater System
Comments: To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region Ensure TV monitor is on so and set to display DVD. 1. Turn system completely off. 2. Turn on system. 3. Open tray. 4. Using remote press and hold the return button. 5. While holding the RETURN button, press and hold the DISPLAY button. 6. You will see something like this displayed on screen: VER 1006 TE 3210 7. Release DISPLAY and RETURN buttons simultaneously. 8. Press the ANGLE button. You will see WRITING REGION ID displayed. You can now play DVDs from any region. 0
May 27, 2007 | Teac PLD2000 System
CD PLAYER
IT MAY BE- IF YOU CAN OPEN IT THEN SEE WEATHER THE COMNNECTION CABELS TO DISPLAY ARE PROPER.IF THEY ARE THEN THE PROBLEM LIES WITH THE POWER SUPPLY TO DISPLAY.
Mar 20, 2007 | Teac PD-H503 3-Disc CD Changer
Teac PD-H500 CD Player Logo
196 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
