Question about Garden
Mowmaster 11hp clean the spark plug
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Do not clean the plug replace it if itbis giving you running and starting issues
Posted on Apr 15, 2014
2 Suggested Answers
  • 6468 Answers
SOURCE: mowmaster 11hp sit on 36 sit on mower fails to drive on uphill gradiants sometimes . any ia deas?
check the drive belt for having oil on it and missing pieces and enough tension
Posted on Jul 16, 2012
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Eingine turns over then seizes with loud clank,took out spark plug and didn't see any movement when turned over with wrench
If this motor is a Briggs and the size is over 11hp, sounds like the counter balance may have broken. If this is the case, then you have no choice but to replace the motor, since when those puppies go, they usually so serious damage,
Apr 12, 2013 | Garden
Mowmaster 11hp sit on 36 sit on mower fails to drive on uphill gradiants sometimes . any ia deas?
Jul 12, 2012 | Briggs & Stratton Garden
Have an older Murray, 38
You need to see if it is getting spark. You can buy a spark tester. You remove the spark plug wire and hook one end of the tester on the spark plug wire and the other end to the spark plug. Crank the engine and see if the tester flashes. Another way to check if you don't have a tester is to insert a screw driver in the spark plug wire and hold the screw driver about 1/16th of an inch or less from the head of the engine and have someone crank it over. You should see a spark jump from the screw driver to the engine. Make sure you're holding the plastic handle of the screw driver or you may feel the shock yourself. If there's no spark, then your mag is bad.
Apr 14, 2010 | Garden
Briggs and stratton 11hp generator giving spark and new fuel pull start but just wont kick over any tips
how long has it been since it last ran? I had a similar problem with mine so I put clean fuel in it with a mixture of sea foam gas treatment. Used a shot of starting fluid to get started and let it run for an hour or so. Just started it again yesterday with no problems. The fuel in carburetor is most likely old and needs to be gotten out of. If you try this and get it started let it run in half choke position for a few minutes so old fuel will get out of caburetor. Good Luck
Feb 17, 2010 | Briggs & Stratton 11HP 6200W Es Generator
Have a problem with a BS600-W-1 generator
With your model number I could see if it has a low oil safety switch I have seen them go bad (check your oil level )
With all wires un plugged from the coil you should have spark
if not coil is bad .
Use another spark plug to test for spark, ground the side of the plug by holding it against some-ting metal on the engine , spark
plug wire hooked to the plug. leave a spark plug in the cylinder
head so gas wont fly out and hit the test spark plug catching fire (seen it done).
Good luck
Feb 02, 2009 | Briggs & Stratton 11HP 6200W Es Generator
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
