Question about Gaggia GRAN Espresso Machine Cappuccino Coffee Maker VGUC Working Italy
Steamer Button doesn't work
Steamer button doesn't stay IN
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Hi ROC,
the steamer works? can you do foam with milk?
perhaps its the thermostat to regule the heat.
sorry, my english level is low, im french.
Posted on Apr 15, 2014
Bass pro turkey fryer wont stay lit
wire around timer or set something on button so runs all time. but also set a cheap alarm or use one on cell phone to remind you time is up.
Feb 25, 2012 | Bass Pro Steamer/Fryer Combos Turkey Fryer
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
Plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Apr 20, 2009 | Homedics PS-200 Iron with Auto Shut-off
Toyota Avalon 1998 A/C Push Button
If when button is pushed in it stays in the AC-light lights up, then you may have another problem like a leak in the system N0/low Freon in system and AC would n't work. But if the switch doesn' t stay push in when its pushed then the switch is BAd and needs to be replace and that will solve the problem. If the switch stays push in with NO AC light on then you may have a bad Ac fuse. Good luck and thanks for using Fix Ya
Mar 18, 2009 | 1998 Toyota Avalon
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Gaggia GRAN Espresso Machine Cappuccino Coffee Maker VGUC Working Italy Logo
141 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
