Gestetner mp1900 error sc 302 - Office Equipment & Supplies
    Habit-Forming:
  • 46 Answers
Problem is charge roller clean Charge roller current leak
Posted on Apr 15, 2014
Functional problem sc 302 in ricoh photocopier model aficio gestetner 1802d, pls help me out, nobody want to help i begged you all. mordecai Olugbenga.
that is a charge roller leak error. try a different photo conductor see if it goes away. If so could be charge roller bad or drum . if it has more then 60,000 copies on it rebuild it .
Mar 04, 2017 | Ricoh Office Equipment & Supplies
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
My printer ricoh 2045 show an error sc 302,not print image correct
i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
Aug 11, 2011 | Ricoh Computers & Internet
@wAm getting a sc 302 code on a gestetner mp 171.I have changed the whole drum unit.
Hello!
When you change the PCU did you conect the blue plug????
If this is not the case remove the PCU again and if you look deep down you will see a metalic shaft. Clean it and install again the PCU.
Hope this helps you
Aug 01, 2011 | Ricoh Aficio 2015 Copier
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Black picture and then sc-302
sc sounds like a scanner code check and see if scan lanp is on when copying. just lift the top cover and hit copy.
Jan 22, 2011 | Gestetner Office Equipment & Supplies
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
k24674
