Question about Radio Communications
Remote wont operate gate
Model 61LM
I whant to program my remote its a wejoin for a sliding gate operator wjkmp201 to a universal remote
follow the programming sequence in the user manual for the gate operation
I suspect that the frequency range of the new remote and the gate opener operation may be different and it will not work but try it any way
Sep 01, 2016 | Universal Televison & Video
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
Why wont my remote open my gate
Agree with Brad. More info needed. Gate Brand and Model as well as Remote model and make.
Apr 15, 2014 | Radio Communications
I have a liftmaster keypad and remote and my code all of a sudden won't work.....additional question...i have an apollo gate that the lift master is wired to ... how do i set up the remote to open the...
My first inclination is that your keypad and remote have been removed from the Logic board memory.
If you have the Opener's instruction manual, then go to the programming section for how to re-program your keypad and remote.
If you do not have your manual then you can go to the Liftmaster website and download / view the manual for your particular unit. You will need the model number for your unit. That can be found near the light fixture on the unit (if you have two light fixtures, then look for a data sticker that indicates Model number and Serial number. You may have to remove or lift the light cover in order to find it.)
This is the link to the Liftmaster website: http://www.liftmaster.com/consumerweb/service/manuals/instructionmanualslanding.htm
To answer your second question, I will need to know what model of gate opener you have, and also need to know if there is a separate Receiver box unit or not. Most Gate operators will have the receiver unit built into them. Some however do not, and an external one will be wired to the gate motor unit, and possibly mounted to a wall near the gate motor. question: do you use the same remote for the gate that you use for the Garage door opener or do you have a separate remote for each? If you do, I need the model number on the remote for the gate operator. That will tell me what kind of tx/rx you have and possibly where to locate the learn button.
May 14, 2011 | liftmaster Chamberlain Garage Door Opener...
I lost my remote to my chamberlain lift master 1000 series garage door What can i do?
Look in the yellow pages for a Chamberlain dealer. They will be glad to sell you a replacement.
Dec 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
May 13, 2010 | liftmaster Chamberlain Garage Door Opener...
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Remote to garage door opener wont work no solution on fixya
The Clicker is a hard one to program. You might try it a couple more times to be sure it won't work.
The 61LM is the Liftmaster remote that goes with that unit. There is a possiblity that the reciever on the board is bad. That board is no longer available but you can get a 635LM external reciever that is backward compatable with the 61LM remote.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Radio Communications Logo
418 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
